output packets late drop
paul amaral
Level 4
Level 4
Hi all, when looking at the interface below I see packet late drops and im trying to determine a few things,
what causes output packet late drops? I'm assuming the sat on the output queue too long to be any good to the other side
how is a packet determined to be late? if there a counter on the output queue
can late packets be anything that uses ips like tcp/udp? I'm assuming yes.
thanks in advance, Paul
Serial8/1/0 is up, line protocol is up
  Hardware is PODS3 Serial
   MTU 4470 bytes, BW 44210 Kbit, DLY 200 usec,
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 2d03h
  Input queue: 0/75/0/118 (size/max/drops/flushes); Total output drops: 1187
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  30 second input rate 23957000 bits/sec, 2847 packets/sec
  30 second output rate 6343000 bits/sec, 1708 packets/sec
     230162732 packets input, 196193195259 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
              0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     189539629 packets output, 110624143393 bytes, 0 underruns
     1187 packets late drop, 1509802 bytes late drop
     0 output errors, 0 applique, 0 interface resets
     0 carrier transitions
   rxLOS inactive, rxLOF inactive, rxAIS inactive
   txAIS inactive, rxRAI inactive, txRAI inactive
0 Replies 0
