PA not getting enabled
umar-rana
Community Member
We have Cisco 7204VXR router with IOS version ?IOS (tm) 7200 Software (C7200-IK9SU2-M), Version 12.3(10a), RELEASE SOFTWARE (fc2)?. We just inserted PA-MC-8E1/120 module. The router show the new interfaces in show version command but the enable light do not turn on.
Please advice if I am missing any step.
Show version output for hardware.
2 FastEthernet/IEEE 802.3 interface(s)
8 Serial network interface(s)
8 Channelized E1/PRI port(s) This is the one
1 Integrated service adapter(s)
125K bytes of non-volatile configuration memory.
One more thing to add, previously 8 port BRI card was installed in the same port.
tdrais
Level 11
Level 11
Do you see the ports if you do a show contollers
On many of these cards you must configure your channel groups before the interfaces appear but I never looked to see if the light is on before you configure the card
umar-rana
Community Member
Yes, I see all the interfaces (controllers). May be you are right. Let me configure it and see.
