PA-T3+= and NM-1T3/E3
a.mir
I wanted to confirm if these cards PA-T3 for 7206 and NM-1T3/E3 for 3825 will work for frame ds3 with 30 meg of port speed and 6 meg of cir circuit,or are they for point to point DS3 only.
Any help is apprciated.
Thanks.
Appears both cards that you mentioned above support fractional DS3 and frame relay encapsulation.
Check out the following links:
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_module_installation_guide_chapter09186a008010b214.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008020eced.html
Pls. rate all helpful posts.
HTH,
Sundar
Thanks sundar
