Packet loss over EoMPLS
mwandu
We are observing the following consistent packet loss on all pseudowires originating from one of the switches - ME3600x running IOS code - System image file is "flash:/me360x-universalk9-mz.153-3.S3/me360x-universalk9-mz.153-3.S3.bin
current uptime;
show ver | i uptim
-UPE-01 uptime is 8 weeks, 5 days, 5 hours, 46 minutes
     timeout is 2 seconds, send interval is 0 msec:
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
  'L' - labeled output interface, 'B' - unlabeled output interface,
  'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
  'M' - malformed request, 'm' - unsupported tlvs, 'N' - no label entry,
  'P' - no rx intf label prot, 'p' - premature termination of LSP,
  'R' - transit router, 'I' - unknown upstream index,
  'l' - Label switched with FEC change, 'd' - see DDMAP for return code,
  'X' - unknown return code, 'x' - return code 0
Success rate is 98 percent (988/1000), round-trip min/avg/max = 1/2/52 ms
 Total Time Elapsed 24944 ms
UPE-01#ping mpls pseudowire 10.220.31.184 2000202 size 1500 repeat 1000
Sending 1000, 1500-byte MPLS Echos to 10.220.31.184,
Success rate is 98 percent (988/1000), round-trip min/avg/max = 1/2/16 ms
 Total Time Elapsed 24804 ms
The pattern of packet drops is very consistent as seen above, two consecutive pings with same result. I have checked system resources and all are within acceptable utilisation thresholds.
What do you think could be issue, platform or code? all was working fine until recently when issue surfaced.
Thank you in advance
0 Replies 0
