Packet Tracer - Can't Ping 2nd router or PC outside of subnet
chris79
Just trying to ping Router3 from PC0
When I inspect the PDU information in the packet when it gets to Router3: "The routing table does not have a route to the destination IP address. The device drops the packet."
First post, been working on this one for a few days, sorry if theres not enough details I can provide more
10 Replies 10
Leo Laohoo
This homework/schoolwork should be posted in the Cisco Learning Network.
Thank you
post the zipped Packet Tracer project (.pkt) file here...
sorry for the late reply. Here is the pkt file
Hi, what's the version of packet tracer u r using?
7.3.0 Build 0838
version 7.3.0
R0--> I tried to assign the IPs you set but I faced overlap error. Could you really assign the IPs you tagged in the picture attached?
Yes, sorry I should have posted a file instead of a picture. For the 6 interfaces connected by the red line (fiber) the subnet mask is 255.255.255.252 (/30) but for every other connection its 255.255.255.240 (/28)
after opening the file, I could see there is no routing (static or dynamic) in place. For the sake of simplicity, I added EIGRP to all routers, which provide end to end  connectivity. Find attached the working file...
