Packet Tracer Connection Issues
karo2307
Community Member
Hi im facing a problem im packet tracer file.
The laptops (that im supposed to connect wirelessly to the the wireless router), adapter isnt turning on. Ive tried all the possible way that i know of.
This is the file.
M02@rt37
Hello @karo2307
Wireless adapter is inactive on Laptop 3 and 4
Go to profile and select the good profile and connect... before add good wifi profile on "Profiles" menu.
After that is Ok !
Best regards
Martin L
for me chaining security mode to WPA2-Personal on WRT3000 and then matching this mode and security password on laptops (not matching initially) did trick.
Regards, ML
**Have fun labbing!!!***
***Please Rate All Helpful Responses ***
