DNA Advantage vs Essential
raghav.rai
I am picking a router for internet connectivity.
All I need is NATing, Static routing , VRF, IPSEC. I am planning to go for C8200-1N-4T. Bit confused whether I need DNA Advantage license or Essential is more than enough ? Please suggest
8 Replies 8
M02@rt37
Hello @raghav.rai
IPSEC ? So DNA Advantage
https://networkdevicesinc.com/community/blog/cisco-network-essentials-vs-network-advantage
Best regards
anudeep thummi
Hi M02@rt37 ,
Thanks for your quick reply but I found the below document which says Network Essentials will support IPSEC as well.
Can you please confirm on the same ?
Cisco DNA Software SD-WAN and Routing Matrices
@raghav.rai
You should be able to achieve that by using Essentials licensing.
Note that Network Essentials and Network Advantage are permanent feature licenses.
Best regards
Hi M02@rt37,
While preparing the BOM, I don't find Newtork Essentials/Advantage instead to add DNA Essentials/Advantage license for C8200 series routers?
I need to implement - "NATing, Static routing, VRF, IPSEC(Crypto)" in C8200 series routers which is Internet Breakout router. Can this be achieved in DNA Essentials?
Chris McCann
You may want to consider long term implications too. Get the DNA Advantage if the budget will allow.
chris.
balaji.bandi
Its all depends on the requirement : (check below image what feature comparison)
If you looking to deploy the features you mentioned i would suggest to go with Network Advantage
Do you have DNAC in the environment ?
BB
anudeep thummi
Hi Balaji,
We don't have DNAC in our environment and need to implement - "NATing, Static routing, VRF, IPSEC(Crypto)" in C8200 series routers which is Internet Breakout router. Can this be achieved in DNA Essentials?
Thanks.
Ssome of them need network advantage license.
the devide come with default essentials.
Configure terminal
license boot level network-advantage
write memory
Reload
this will give you 90 days buffer time to test and buy a License.
BB
