Packet Tracer DHCP Server issue
NinjaTurtle2021
Hi can someone help with my packet tracer ?
My DHCP Server is seemingly not working and doesn't issue any IP addresses to my vlans.
My packet tracer is attached to this post.
Many thanks if you can help me
2 Accepted Solutions
Martin L
DHCP Server page is not configured properly;  You have Subnet Mask in pace where IP should be; Right now I see "Start IP Address"  is 255.255.255. but it should be IP like 10.0.50.x
and then Subnet Mask 255.255.255.x
to make things run faster (better) you can enable PortFast feature on all switches access ports.
Regards, ML
**Please Rate All Helpful Responses **
Your DHCP server has an IP address in the 192.168.200.0/24 range, with a default gateway in the 192.168.201.0/24 range. Your ip helper-addresses point to the 192.168.200.0/24 range. Change the IP addressing so it matches.
6 Replies 6
Martin L
Regards, ML
Thanks sir ! Seems I was kinda exhausted when I configure the server x)
I corrected the masks and the IP addresses in the DHCP server but still it doesn't give any IP addresses to my vlans.
Could you please help me again ?
The packet tracer is attached to this post
Thanks for your help sir, it works now !
Have a nice day !
aashishjoshi661
a
