Packet Tracer Help Needed!
Billdog
So i've just set up a network on Packet Tracer including 2 PC's, 2 Routers and 1 web server.
The thing is how do i get packet tracer to show me sending web traffic from one PC to another?
i've tried the "simulation" on Packet Tracer but that is just god awful.
9 Replies 9
post the Packet Tracer project file (.pkt). ZIP it first otherwise the system won't let you upload it...
Thanks for the quick response, i've attached the pt file
I have added Netflow to your routers. On the server, go to Desktop and click on Netflow Collector. You should see a pie chart displaying traffic.
Is that what you are after ?
On the Right router we need to create an ACL that will prevent any odd-numbered IP addressed network devices represented by Right-PC from being able to reach any even-numbered IP addressed device in the network occupied by Left-PC, when any device is using HTTP and HTTPS traffic.
how would i go about this aswell?
Hi @Billdog,
You must make some changes in your topology:
1-You must add the DNS server IP(192.168.1.2) in the two PCs
2-You must add the ip of the network where the DNS server is located(192.168.1.0) in the EIGRP configuration on the router Right
3-The DNS server is also your WEB server, so only that ip (192.168.1.2) will respond to your WEB requests (according to your configuration, only the web page http://dns)
On the Right router I need to create an ACL that will prevent any odd-numbered IP addressed network devices represented by Right-PC from being able to reach any even-numbered IP addressed device in the network occupied by Left-PC, when any device is using HTTP and HTTPS traffic.
How would i go about this aswell
Hi @Billdog,
I think that this ACL could work in that case:
right(config)#access-list 100 deny tcp 192.168.0.1 0.0.0.254 10.0.0.0 0.0.0.254 eq 80
right(config)#access-list 100 deny tcp 192.168.0.1 0.0.0.254 10.0.0.0 0.0.0.254 eq 443
right(config)#access-list 100 permit ip any any
right(config)#int f0/0
right(config-if)#ip access-group 100 in
that works fine. is there a way to find if the packets are being dropped?
Hi @Billdog,
Yes, add a server in the PC-Left network and assign an even-numbered IP address within the same network.PT10.jpg
Then, in the PC-Right try to find the IP of that server with the web browser.
