Password recovery on ASR 1006
Amos Kafwembe
Hi all,
I am trying to perform a password recovery on a Cisco ASR 1006, I can ctrl + break and set the register to 0x2142, i then power cycle it, but it keeps booting back into the 0x2102 register. is there anything different about this device?
Leo Laohoo
Some smart a$$ must've enabled "no password-recovery".  Can you inspect the appliance and see if there is a tiny "RESET" button available?
If there is none, then you need to read (carefully) THIS.
thanks, though this procedure is what worked;
http://www.networking-guru.net/2011/04/asr1006-dual-route-processors-password_6168.html
wangzixiong
This problem should be redundant routing engine. Pull one engine out and try again would be solve this problem.
