PBR ASR100x
Qudama Khalil
i need make two PBR on the vlan can any one do as asimplest way?
M02@rt37
Hello @Qudama Khalil
Only one ip policy command can be applied to an interface at a time. This means you can't apply two PBR directly on the same VLAN interface.
You could apply multiple PBR actions on the same interface, you should combine multiple conditions within a single route map.
Example:
# First PBR policy in the route map
Switch(config)# route-map PBR_COMBINED permit 10
Switch(config-route-map)# match ip address PBR1_ACL
Switch(config-route-map)# set ip next-hop 10.10.10.1
# Second PBR policy in the same route map
Switch(config)# route-map PBR_COMBINED permit 20
Switch(config-route-map)# match ip address PBR2_ACL
Switch(config-route-map)# set ip next-hop 10.10.20.1
Switch(config)# interface Vlan10
Switch(config-if)# ip policy route-map PBR_COMBINED
Best regards
5 Replies 5
msalman0203903
Just as PBR on ASR100x routers helps optimize network traffic, Stardew Valley requires players to strategically manage their farm's layout and resources, ensuring efficient operations and maximizing productivity. Both involve thoughtful planning to achieve the best outcomes.
No you can not use two different pbr under one vlan svi' but you can use two line (each line have match and set) under one pbr and then add this PBR under vlan svi.
MHM
M02@rt37
Example:
Best regards
Thanks alot its works as you mentioned 100%
You're so welcome @Qudama Khalil
Best regards
