PBR configuration
teymur azimov
Hi Dears,
that is my subnetting at my cisco router.  i want 172.100.3.0, 172.100.6.0,172.100.10.0 subnetting forward to ISA server(192.168.1.10). this subneting go to internet througth ISA server. is it possible i do that PBR? if yes please help me how can i do it?
thanks.
interface GigabitEthernet0/1.3
encapsulation dot1Q 3
ip address 172.100.3.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/1.4
encapsulation dot1Q 4
ip address 172.100.4.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.5
encapsulation dot1Q 5
ip address 172.100.5.254 255.255.255.0
interface GigabitEthernet0/1.6
encapsulation dot1Q 6
ip address 172.100.6.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 172.100.10.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 172.100.1.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.777
encapsulation dot1Q 777
ip address 192.168.1.254 255.255.255.0           ISA server
ip nat inside
teymur azimov
please consider that all my subnetting are the same router.
Try this:
ip access-list extended PBR
deny ip 172.100.0.0 0.0.255.255  172.100.0.0 0.0.255.255
permit ip 172.100.0.0 0.0.255.255 any
route-map PBR
match ip address PBR
set ip next-hop 192.168.1.254
interface g0/1.3
ip policy route-map PBR
interface g0/1.6
interface g0/1.10
Regards.
Alain
thanks to reply me.
i have one question.
why we write
deny ip 172.100.0.0 0.0.255.255  172.100.0.0 0.0.255.255  command?
please consider that that subnet's must connect each other.
I did this to get sure the subnets when they talk to each other are not redirected to ISA server but only when thy go elsewhere that is to the Internet for example.
Regards.
Alain
