PBR ECMP using Recursive Next Hop on Catalyst 3650
RameshPVN8915
I was trying to do PBR ECMP on Cat3650 using recursive next hop and running into issues that the RouteMap has unsupported options. Software Version was 3.7.5E.
I created a small topology of 2 L3 Ports (20.1.1.1/30 20.1.1.5/30) having one L3 next hop (20.1.1.2, 20.1.1.6) each on them (directly connected).
I created a recursive next hop 30.1.1.1 which is reachable via 20.1.1.2 and 20.1.1.6 (equal cost). The route-map has set ip next hop recursive as 30.1.1.1 and I expect traffic to be load balanced between the 2 next hops.
This is the switch:-
Switch Ports Model              SW Version        SW Image              Mode
*    1 28    WS-C3650-24PD      03.07.05E         cat3k_caa-universalk9 INSTALL
This is the syslog seen :-
*Aug  2 05:58:16.207: %PLATFORM_PBR-3-UNSUPPORTED_RMAP: Route-map pbrmap2 has unsupported options for Policy-Based Routing. It has been removed from interface, if applied.
My question is whether its not supported by this platform or in this software release in this platform.
Or am I doing fundamentally something wrong here :-). Any pointers will help.
Ramesh
RameshPVN8915
Here is the output from switch:
cisco1#sh route-map pbrmap2
route-map pbrmap2, permit, sequence 10
  Match clauses:
    ip address (access-lists): pbr1
  Set clauses:
    ip next-hop recursive 30.1.1.1
Nexthop tracking current: 30.1.1.1
30.1.1.1, fib_nh:3CD08684,oce:38175DF4,status:1
  Policy routing matches: 0 packets, 0 bytes
cisco1#sh ip route 30.1.1.1 255.255.255.255
Routing entry for 30.1.1.1/32
  Known via "static", distance 1, metric 0
  Routing Descriptor Blocks:
  * 20.1.1.6
      Route metric is 0, traffic share count is 1
    20.1.1.2
cisco1#
cisco1#sh run
cisco1#sh running-config in
cisco1#sh running-config interface vl
cisco1#sh running-config interface vlan 10
Building configuration...
Current configuration : 60 bytes
interface Vlan10
 ip address 10.10.1.1 255.255.255.0
end
cisco1#sh logging
*Aug  2 17:11:20.433: PBR Nexthop Callback invoked: 3A5FA628, (30.1.1.1) tableid 0, status: 2,type: SET NEXTHOP RECURSIVE
*Aug  2 17:11:20.433: map: pbrmap2, sequence: 10
PBR Control Plane Notification: 30.1.1.1 PBR_CP_SET_NEXTHOP_RECURSIVE
*Aug  2 17:11:20.433: PBR CP Notification sent: Type:SET NEXTHOP RECURSIVE, 30.1.1.1SW_OBJ_TYPE: 1D, SW_HANDLE: 3D2D41B0
*Aug  2 17:11:26.899: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/10, changed state to up
*Aug  2 17:11:27.897: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/10, changed state to up
*Aug  2 17:11:27.902: PBR Nexthop Callback invoked: 3A5FA628, (30.1.1.1) tableid 0, status: 2,type: SET NEXTHOP RECURSIVE
*Aug  2 17:11:27.902: map: pbrmap2, sequence: 10
*Aug  2 17:11:27.903: PBR CP Notification sent: Type:SET NEXTHOP RECURSIVE, 30.1.1.1SW_OBJ_TYPE: 15, SW_HANDLE: 38175DF4
*Aug  2 17:14:17.542: %PLATFORM_PBR-3-UNSUPPORTED_RMAP: Route-map pbrmap2 has unsupported options for Policy-Based Routing. It has been removed from interface, if applied.
Hello Ramesh,
the feature looks like unsupported on your switch with your current software image.
Check the current SDM template (the way the TCAM is used on the switch ) using
show sdm prefer
to see if there is a more advanced routing SDM template that could be used.
However, for the way a multilayer switch works PBR can work in hardware only if the TCAM can support it.
With a standard set ip next-hop command the TCAM can be programmed with a pointer to the next-hop for each CEF entry that will be processed by PBR.
The recursive next-hop option  requires more intelligence as the next-hop has to be resolved in multiple ECMP next-hops by recursion. This capability may be supported on higher end switches like C6500, C6800.
We should check with the feature navigator.
In practice you can easily create a workaround for this:
use L3 port-channel with two member links instead of two routed links you can achieve link redundancy and flow based  load balancing over the etherchannel the L3 next-hop for PBR will be the other end of the L3 port channel. In this way you don't need to use the recursive option.
Edit:
link to feature navigator
https://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
I used as filter the word PBR.
There is an entry for PBR support for IPV6 recursive next-hop that points to the following link:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/configuration/xe-3s/iri-xe-3s-book/iri-pbr-rec-next-hop-support.html
IOS XE 3 likely on ASR 1000. However, it provides an explanation of how PBR set next-hop recursive is implemented.
Hope to help
Giuseppe
Thanks for your response. I already went through these parts.
The 3650 documentation says the support was added for this feature in 3.6. and I have 3.7 - so it should work and unfortunately it does not.
Will check if the newer catalyst 9000s support it.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/configuration/xe-3e/iri-xe-3e-book/iri-pbr-rec-next-hop-support.pdf
