PBR Issue Cisco 2 x ISP problems
rasoftware
I a situation with and 1800 router setup for dual ISP access managed by PBR.
1 x FE Interface (SDSL-EASYNET) and 1 x ATM/Dialer (BT)
This was working ok before we upgraded the 1 x FE connection from ADSL - SDSL (same ISP and same IPs as before).
If I remove the PBR I can ping the tracked IP from the FE interface. However, if I shut down then start the FE interface the "track" remains down.
I have the following config - not sure how to debug this and it driving me mad!
(212.58.224.82 - bbc IP)
interface FastEthernet0
description $ETH-LAN$
ip address 195.172.x.x 255.255.255.240
ip nat outside
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip address 192.100.151.2 255.255.255.0
ip nat inside
ip sla 1
icmp-echo 212.58.224.82 source-interface FastEthernet0
timeout 10000
threshold 2
frequency 15
ip sla schedule 1 life forever start-time now
track 100 rtr 1 reachability
ip local policy route-map LOCAL_POLICY
ip route 0.0.0.0 0.0.0.0 195.172.169.17 track 100
ip route 0.0.0.0 0.0.0.0 Dialer0 254
access-list 101 permit icmp any host 212.58.224.82 echo
access-list 40 remark IPs for NAT policy
access-list 40 permit 192.0.0.0 0.255.255.255
ip nat inside source route-map ispA interface FastEthernet0 over
ip nat inside source route-map ispB interface Dialer0 overload
route-map LOCAL_POLICY permit 10
match ip address 101
set interface Null0
set ip next-hop 195.172.169.17
route-map ispB permit 10
match ip address 40
match interface Dialer0
route-map ispA permit 10
match ip address 40
match interface FastEthernet0
dan.cicioiu
Hi ,
i think you have a high timeout. Let the timeout
, threshold and frequency with the default values and it will work.
