PBR next hop interface failover
Hi Community,
I have a Cisco 819G router which I've setup to use ADSL on the Dialer0/Gigabit0 interface, and 3G on the Dialer2/Cellular0 interface. I've setup a route-map on the VLAN1 interface to load balance the internet connections based on protocol. I've currently got web (HTTP, HTTPS) going out ADSL/Dialer0/Gigabit0 and SSH going out 3G/Dialer2/Cellular0 as a test example. However, if the ADSL goes down, the route-map doesn't failover to the 3G/Dialer2/Cell0 interface and vice versa. How could I set this up so that my policy based routing will failover to the other internet connection if one is down? I would've expected the static routes to take over if the PBR couldn't route out the specified interface, but that doesn't happen.
Current running configuration below. I can run any commands on this service you like. The ADSL service is currently unplugged as it's supporting the client's existing setup while we get this Cisco router right, but I can arrange to have it connected after hours.
QUESTION: Is there a way to get policy based routing (PBR) to failover to another interface if the specified next hop interface is down?
QUESTION: I would also like to load balance connections made over the VPN based on PBR policies. E.g. SMB3 via 3G and other traffic destined for the server via ADSL.
Many thanks, and for any readers who find this helpful, please login and mark the authors posts as helpful.
CQROU01#show run
Building configuration...
Current configuration : 6984 bytes
! No configuration change since last restart
version 15.1
hostname CQROU01
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
clock timezone AEST 10 0
crypto pki trustpoint TP-self-signed-584703432
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-584703432
revocation-check none
rsakeypair TP-self-signed-584703432
crypto pki certificate chain TP-self-signed-584703432
certificate self-signed 01
### REMOVED SELF SIGNED CERTIFICATED DETAILS###
        quit
ip source-route
ip cef
###REMOVED IP DOMAIN NAME###
ip name-server 172.16.1.1
ip name-server 4.2.2.2
ip name-server 8.8.8.8
no ipv6 cef
chat-script hspa "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
license udi pid C819G+7-K9 sn FGL1707237S
###REMOVED LOCAL ADMIN ACCOUNT CREDENTIALS###
controller Cellular 0
gsm sim profile 2 slot 1
gsm sim max-retry 12
gsm failovertimer 1
track 101 ip sla 101 reachability
track 102 ip sla 102 reachability
default-state up
delay down 180
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes 256
group 5
###REMOVED CRYPTO ISAKMP KEY PASSWORD ADDRESS DC INTERNAL ASA PUBLIC IP###
crypto isakmp keepalive 10
crypto ipsec transform-set TRANSFORM_ESP_SHA_AES256 esp-aes 256 esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
###REMOVED DESCRIPTION OF PUBLIC ADDRESS OF DC INTERNAL ASA###
###REMOVED SET PEER OF PUBLIC ADDRESS OF DC INTERNAL ASA###
set transform-set TRANSFORM_ESP_SHA_AES256
match address 100
crypto map SDM_CMAP_2 1 ipsec-isakmp
match address 101
interface Loopback0
ip address 172.16.3.1 255.255.255.0
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer pool-member 2
dialer-group 2
async mode interactive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
ip nat outside
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
description $ETH_LAN$
ip address 192.168.10.9 255.255.255.0 secondary
ip address 172.16.2.1 255.255.255.0
ip helper-address 172.16.1.1
ip nat inside
ip tcp adjust-mss 1452
ip policy route-map LOAD_BALANCE
interface Dialer0
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
ppp authentication chap pap callin
###REMOVED PPP CHAP HOSTNAME###
###REMOVED PPP CHAP PASSWORD###
no cdp enable
interface Dialer2
ip nat outside
encapsulation slip
dialer pool 2
dialer string hspa
dialer persistent
dialer-group 2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map NAT-DIALER1 interface Dialer0 overload
ip nat inside source route-map NAT-DIALER2 interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 track 101
ip route 0.0.0.0 0.0.0.0 Dialer2 track 102
ip access-list extended CQLAN
remark CCP_ACL Category=18
remark IPSec Rule
deny   ip 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
permit ip 172.16.2.0 0.0.0.255 any
permit ip any any
ip access-list extended TRAFFIC_FOR_DIALER0
permit tcp any any eq www
permit tcp any any eq 443
deny   ip any any
ip access-list extended TRAFFIC_FOR_DIALER2
permit tcp any any eq 22 log
deny   ip any any
ip sla 101
icmp-echo 203.12.160.35 source-interface Dialer0
frequency 10
ip sla schedule 101 life forever start-time now
ip sla 102
icmp-echo 203.12.160.35 source-interface Dialer2
frequency 10
ip sla schedule 102 life forever start-time now
access-list 1 permit any
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
access-list 101 remark CCP_ACL Category=4
access-list 101 remark IPSec Rule
access-list 101 permit ip 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
no cdp run
route-map LOAD_BALANCE permit 10
match ip address TRAFFIC_FOR_DIALER0
set interface Dialer0
route-map LOAD_BALANCE permit 20
match ip address TRAFFIC_FOR_DIALER2
set interface Dialer2
route-map NAT-DIALER1 permit 10
match ip address CQLAN
match interface Dialer0
route-map NAT-DIALER2 permit 10
match interface Dialer2
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line 3
script dialer hspa
modem InOut
no exec
rxspeed 21600000
txspeed 5760000
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
login local
monitor
transport input telnet ssh
scheduler allocate 20000 1000
event manager applet CLEAR_NAT_ON_BOOT
event track 101 state up
action 1.0 cli command "clear ip nat trans *"
event manager applet SET-3G-TRACKING-UP-AT-BOOT
event timer cron cron-entry "@reboot"
action 1.0 wait 30
action 2.0 track set 102 state up
end
CQROU01#
5 Replies 5
cadet alain
For PBR failover you should use set ip next-hop x.x.x.x verify-availability track   command instead of set interface.
Alain
Hi Alain,
Thanks for your help. Although my next hop interface is dynamic in the case of 3G so I can't use this command. When I type "set interface dialer2" the only subsequent option is another interface. Does adding a second interface to this command cause it to use this second interface if the first is unavailable? If so, how does the route-map know that the first interface is unavailable?
Thanks.
if the outgoing interface line protocol is up then it will use this one and you may have a problem out one ISP but still have the corresponding interface up so it will not try the second one as far as I know.
Alain
Hi Alain,
I just tried the command "set interface Dialer0 Dialer2" under the route map and the results I found were:
If I do a "show ip interface brief", dialer0 for the ADSL remains in status: up, line protocol: up, even though the underlying physical interface gigabit0 is disconnected.
Using the the command "set interface Dialer0 Dialer2" didn't provide connectivity where the Dialer0(ADSL) interface was not connected to the ADSL service. However, when removing it and replacing it with "set interface Dialer2(3G)", with the 3G service up, it did provide connectivity for the matched statements.
My conclusion is that route-map failover using the "set interface" command is not effective.
My next thoughts are that our ADSL service IP is static, and therefore the next hop will also be static. So, I could use route mapping to specify only what comes in via the ADSL service, and have everything else traverse the 3G link by default. In the event that the ADSL goes down, I could use the route-map to failover to run everything off the 3G service. This doesn't account for the possibility of the 3G service going down, but I would not expect that to happen.
Thanks Alain. I rated your post as very helpful.
Without resorting to hardcoding the ip of the isp ipcp gateway as the next-hop in the route-map since it could change down the road and break things, Is there a way to take the gateway supplied by the isp at the time the dialer ppp ipcp is negotiated and have it pass dynamically into some form of route-map next-hop verify-availability statement that permits failover to the other isp if an sla object tracked/sourced on that interface and associated with it in the route-map goes down?  Have no problem with failover/pbr/sla senarios with static isp's but it gets murky with these dynamic pppoe dialers.  I've gotten an approximation of the desired results with floating static routes pointed at the dialer interface tied to sla tracked objects routed to the dialer interface but it's not pbr.
