PBR Not updating
Hi all, I hope you can help.  I have 2 issues.
We're implementing PBR to assist in firewall migration.  Because of the number of users/departments and suppliers we have traversing our connection, rather than big bang, rip out old add new, we're doing piecemeal.
Traffic is being passed into a 6509 L3 interface, with two separate L3 interfaces for outbound to old and new.
When applied for the first time with some test addresses this policy works fine, and continues to work for the first three entries into the acl.
Issue 1, when I add my IP as a source, I loose ssh access to the router.
Issue 2, when I add new addresses to the migrate ACL (in this case the 4th line), they're still being passed down the old route. as seen through the acl output
PBR-Router#sh access-list
Extended IP access list migrate
10 permit ip host 10.132.25.106 any (6 matches)
20 permit ip any host 62.253.228.16 (3 matches)
30 permit ip host 10.132.25.88 any (3 matches)
40 permit ip 10.45.0.124 0.0.0.3 any
Extended IP access list remain
10 permit ip any any (9334043 matches)
Config is as below
interface GigabitEthernet9/1
description route to lan
ip address 192.168.3.29 255.255.255.252
no ip redirects
ip policy route-map new-fw
interface GigabitEthernet9/2
no ip address
shutdown
interface GigabitEthernet9/3
description route to old FW
ip address 10.132.27.230 255.255.255.240
no ip redirects
interface GigabitEthernet9/4
description route to new FW
ip address 10.132.30.243 255.255.255.128
no ip redirects
ip access-list extended migrate
ip access-list extended remain
permit ip any any
route-map new-fw permit 10
match ip address migrate
set ip next-hop 10.132.30.241
route-map new-fw permit 20
match ip address remain
set ip default next-hop 10.132.27.225
just to be sure, is the line 'set ip default next-hop 10.132.27.225' on purpose ? Traffic would only be policy routed if the destination address does not exist in the routing table, contrary to the 'set ip next-hop', where traffic is policy routed if the destination does exist in the routing table.
6 Replies 6
Jon Marshall
Firstly the 6500 does PBR in hardware so using the acl hits is not necessarily accurate, traceroute is your friend here.
Secondly why are you doing PBR for both sets of traffic ie. presumably you have a default route on the 6500 for the existing traffic in which case you only need to do PBR for the traffic you do not want to use the default route.
As for your host traffic not being able to SSH it is probably because the PBR is picking up the traffic and sending it to the next hop. You need to exclude the specific traffic between your host and the switch IP in the acl before the permit any for your host.
Jon
Hi Jon,
I did think about that, but when the IT VLAN gets migrated I'm going to need to use the PBR from my client, but still access the switch.
I think the set ip default next hop is what's needed.
your route map:
It means that if 10.132.27.225 exists, nothing will be policy routed. If it doesn't exist, everything specified in the ACL 'remain' will be policy routed. Kind of weird actually, but that is how it supposedly works...
http://www.cisco.com/c/en/us/support/docs/ip/ip-routed-protocols/47121-pbr-cmds-ce.html#intro
Thanks for help all
Solution for my scenario was to add default to policy entry 10.
Hi Georg,
I've just uploaded a quick diagram.
You may have spotted the config.  I want ANYTHING in the ACL to be PBR, unless the route already exists.
I'll try changing that.
