03-01-2017 01:20 AM - edited 03-05-2019 08:07 AM
I've just put a new EHWIC-4ESG card in a Cisco 1921, but it is not showing in sh run.
It appears in sh invent and sh diag, so I can see the router picking it up, but can't for the life of me get it to show in the running config.
there is only one card in the router and we have tried both WIC slots, but still nothing. Router has been rebooted several times, but nothing seems to work.
Router software is 15.4(3)M3 (so fairly new).
What am I missing? Is there a command which disables the card, or could the card just be faulty, which i find hard to believe if the router itself is seeing it. There is no mention of unsupported card etc either.
03-01-2017 02:22 AM
I can't find any bugs associated with this release either.
03-01-2017 02:31 AM
doesn't mean you have not hit something just because its not in the release notes for that version , this is one of the current 2 recommended releases to be on for that platform
c1900-universalk9-mz.SPA.154-3.M7.bin
Worth a shot replacing software before hardware , if you have already reseated it and powered on/off the router , theres not much more you can do as there auto sensed wics , once there in inventory it should add itself to running config after a reboot
03-01-2017 02:24 AM
They should just take in running once its in inventory , theres no command to turn it on
Its an ISR G2 1921 yes ? G1s don't support ehwics fully
I would try a different ios version rule out the software version your on
Integrated Services Router Version |
Minimum Cisco IOS Software Release |
Cisco 1900 Series: Cisco 1921 and 1941 |
15.1(2)T: IP Base |
03-01-2017 02:27 AM
yes definitely an ISR G2 1921.
That is my next plan, although is a live system, so will need to upgrade out of hours.
