PBR on CoreSwitch to forward http,https request to Proxy Server
sreeraj.murali
Level 3
Level 3
Hi Experts,
We are planning to put a proxy server in the network. Since we don't want to make any changes on the End User PC Browser, we want to forward all the End User HTTP, HTTPS request hitting the default gateway(Core Switch-172.20.4.1) to the proxy server(172.20.4.100) and again reforwarding the traffic to LAN Switch and then to ASA Firewall.
Please find the attached diagram.
Sreeraj
12 Replies 12
below is a basic PBR configuration. What core switch (model) do you have, and which IOS version are you running ?
access-list 101 permit tcp any any eq 80
access-list 101 permit tcp any any eq 443
route-map HTTP_HTTPS permit 10
match ip address 101
set ip next-hop x.x.x.x
route-map HTTP_HTTPS permit 20
interface Vlan10
ip policy route-map HTTP_HTTPS
Thanks for the prompt response !!!
It is Cisco WS-C3850-48P hardware.
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.03SE RELEASE SOFTWARE (fc2).
Also, please do suggest, if the diagram attached, is a valid Network design for introducing proxy server in the network.
Best Regards
Sreeraj
in your diagram it looks like the proxy server is sitting between the core switch and the firewall, so all traffic goes through the proxy server by default anyway ?
Yes, planning to route all HTTP, HTTPS traffic thru the proxy server. This is the design.
PC===>3850CoreSwitch==>Squid Proxy Server==>ASA Firewall.
Please help with below points as well
1. Will this work?
2. Hope we can connect the PC NIC Interface to ASA Firewall as INSIDE Interface?
3. Will there be an issue with reverse traffic from Internet through AS back to proxy and PC?
Best Regards
Sreeraj
Going through the "flow chart" you uploaded I feel we need to take a step back here.. the PC's, Proxy and the ASA are all on the same LAN segment in the same VLAN. I honestly do not see how route-maps will assist you when you are performing Layer 2 forwarding based on MAC-Address.... If you can draw up an actual network diagram it would assist in providing you with design ideas for your issue. And if your proxy is listening for proxy connections to say port 3128 or port 8080 for example, then further down the rabbit hole we go... I'm not too confident in this design tbh..
Thanks Tinashe Ndhlovu for the expert input.
I am attaching the detailed Network diagram. Please check and suggest, with the design, configuration.
Also, suggest with the below points.
  1. Hope we can connect the PC NIC Interface to ASA Firewall as INSIDE Interface?
  2. Will there be an issue with reverse traffic from Internet through AS back to proxy and PC?
Best Regards
Sreeraj
Could you please help with more light on this? May be, if a design change is required to achieve this.
Best Regards
Sreeraj
Please comment with your experts inputs.
Hello
Hello you dont say what core switch your using but maybe web cache communication protocol (WCCP) would be applicable:
Basically you specify a forwarding proxy and apply it to the outgoing interface L3 interface of you core switch or router towards the proxy.
access-list 10 permit 172.20.4.100
ip wccp web-cache group-list 10
ip wccp web-cache
interface x/x
ip wccp web-cache redirect out
res
Paul
Kind Regards
Paul
Thanks Paul driver for providing this valuable input. I will try this.
Could you also suggest, If the attached design works.
1. Will this work?
Best Regards
Sreeraj
Could you please help with the design.
Best Regards
Sreeraj
Hi Paul,
Thanks for your input on the WCCP Web-Cache redirect.
But, what would be the case, when the redirected traffic to proxy, comes back again to the Core Switch, It will create an infinite loop.
Please provide your comments.
