PBR "continue" problem
jackie_gx
there seem a problem with the "continue" with my pbr.
i want to match source and destination of a packet.
Refer to the pbr i capture below, i want it, if match the permit 10 it will go to permit 30.
But what i see my my capture data, there is no traffic at all at the permit 30.
What can be the problem?
route-map PBR, permit, sequence 10
  Match clauses:
    ip address (access-lists): SOU
  Continue: sequence 30
  Set clauses:
  Policy routing matches: 4357054 packets, 1853382698 bytes
route-map PBR, permit, sequence 20
  Match clauses:
  Continue: sequence 40
  Set clauses:
  Policy routing matches: 3114521 packets, 879205075 bytes
route-map PBR, permit, sequence 30
  Match clauses:
    ip address (access-lists): DEST
  Set clauses:
    ip next-hop verify-availability x.x.x.x 1 track 1  [up]
  Policy routing matches: 0 packets, 0 bytes
route-map PBR, permit, sequence 40
  Match clauses:
  Set clauses:
7 Replies 7
Peter Paluch
Hi Jackie,
I am not 100% sure here but it has been my understanding that the continue clause in route-maps is only effective when route-maps are used in redistribution or BGP routing policies (attribute modification). The continue clause is not inteded to be used in policy-based routing. That may explain the fact that in your route-map, it does not have any effect.
Best regards,
Peter
Hi Peter
Cos the ACL list is too long to write for every ACL with source and dest.
So i write a ACL that match source and other ACL that match dest.
How we write a route-map to macth both ACL?
TQ
from
jackie
Hello Jackie,
If you need to match two ACLs in a single route-map entry, you simply reference them in multiple match statements, as follows:
route-map Example permit 10
  match ip address 101
  match ip address 102
  set ...
Best regards,
Peter
Hi Peter
that match u mention above won't work cos when u type
it will show like this :
match ip address 101 102
TQ
from
jackie
Hello Jackie,
That is interesting. What platform and IOS version are you running?
Best regards,
Peter
Hi Peter
think all ios will be the same behavior, when u match the same "type", it will always become logical OR.
only if u match the diff "type", it will become logical AND.
like:
match ip add 101
mtach tag
TQ
from
Chai
Jackie,
You are absolutely correct here. I apologize for my mistake.
Hmmmm, we have a problem here, then. For PBR, route-maps are the mandatory configuration component. However, specifying a multiple match of the same type will lead to a logical OR, exactly as you have shown. I was thinking of matching a class-map that can be configured in a match-all mode with multiple ACLs, but sadly, a route-map does not allow matching a class-map. And as you have demonstrated yourself, the continue clause is not working, either.
At this point, I am unable to provide any suggestion. I am not saying that there is no way of doing this but right now, I do not see any possible way of accomplishing that. If I come across anything useful I'll make sure to post it here.
Best regards,
Peter
