Per-Session QoS | LNS QoS | PPP session | per-vc QoS configuration Template
G'day All,
Please find the configuration template for Per-Session QoS. It is on LNS, applied on L2TP session by Radius (vendor specific attributes).
IOS version: c7301-advipservicesk9-mz.152-4.S4.bin
This did not work on:
c7301-advipservicesk9-mz.151-4.M7.bin
c7301-advipservicesk9-mz.124-24.T8.bin
Radius Attributes:
For Input/output policy:
ip:sub-policy-In=<Cust-Name>-EDGE-IN
ip:sub-policy-Out=<Cust-Name>-OUTPUT
Other attributes:
lcp:allow-subinterface=yes
lcp:interface-config=ip vrf forwarding <Cust-Name>
lcp:interface-config=ip unnumbered Loopback 149
Router Configuration:
E2-LNS-01#sh runn clas
E2-LNS-01#sh runn class-map CUST:GOLD
class-map match-any CUST:GOLD
match ip precedence 5
end
E2-LNS-01#sh runn class-map CUST:BRONZE
class-map match-any CUST:BRONZE
match ip precedence 0
end
E2-LNS-01#sh runn policy-map <Cust-Name>-EDGE-IN
class CUST:GOLD
set mpls experimental imposition 5
class CUST:BRONZE
  set mpls experimental imposition 0
end
E2-LNS-01#sh runn policy-map <Cust-Name>-OUTPUT
class class-default
  shape average 10000000
   service-policy <Cust-Name>-OUTPUT-CHILD
end
E2-LNS-01#sh runn policy-map <Cust-Name>-OUTPUT-CHILD
class CUST:GOLD
  bandwidth 2000
class CUST:BRONZE
end
E2-LNS-01#
Logs:
E2-LNS-01#sh subscriber session | in sws
46      Vi2.3        authen   Lterm       00:01:49 0     <Cust-Name>@hellothere.com.au
E2-LNS-01#show policy-map session
SSS session identifier 46 -
  Service-policy input: <Cust-Name>-EDGE-IN
    Class-map: CUST:GOLD (match-any)
      0 packets, 0 bytes
      30 second offered rate 0000 bps, drop rate 0000 bps
      Match: ip precedence 5
        0 packets, 0 bytes
        30 second rate 0 bps
      QoS Set
          Packets marked 0
    Class-map: CUST:BRONZE (match-any)
      0 packets, 0 bytes
      Match: ip precedence 0
        0 packets, 0 bytes
      QoS Set
          Packets marked 0
    Class-map: class-default (match-any)
      7 packets, 437 bytes
      Match: any
  Service-policy output: <Cust-Name>-OUTPUT
      8 packets, 887 bytes
      Match: any
      Queueing
      queue limit 2500 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 5/619
      shape (average) cir 10000000, bc 40000, be 40000
      target shape rate 10000000
      Service-policy : <Cust-Name>-OUTPUT-CHILD
          0 packets, 0 bytes
            0 packets, 0 bytes
          Queueing
          queue limit 500 packets
          (pkts output/bytes output) 0/0
          bandwidth 2000 kbps
          0 packets, 0 bytes
            0 packets, 0 bytes
          Match: any
          queue limit 2000 packets
E2-LNS-01#
Ref:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_perssn/configuration/15-s/qos-perssn-15-s-book/qos-perssn.html
Cheers,
0 Replies 0
