08-18-2010 09:43 AM - edited 03-04-2019 09:28 AM
Hi, recently I enabled MLS qos i understand this works with packets that are hardware switched in the PFC. Is it recomend or should i also setup some other queueing method such as CBWFQ for packets that get software switched?
Mod Ports Card Type Model Serial No.
1 48 SFM-capable 48-port 10/100 Mbps RJ45 WS-X6548-RJ-45 SAL0751QS8S
2 48 SFM-capable 48-port 10/100 Mbps RJ45 WS-X6548-RJ-45 SAL0749Q6TF
5 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAL09158YJ2
6 2 Supervisor Engine 720 (Hot) WS-SUP720-3BXL SAL1028UPGH
8 0 2 port adapter FlexWAN WS-X6182-2PA SAD04320GGC
core.#sh mls qos
QoS is enabled globally
Policy marking depends on port_trust
QoS ip packet dscp rewrite enabled globally
Input mode for GRE Tunnel is Pipe mode
Input mode for MPLS is Pipe mode
QoS Trust state is DSCP on the following interface
Fa1/14 Fa1/15 Fa1/17 Fa1/47 Fa2/27
Vlan or Portchannel(Multi-Earl) policies supported: Yes
Egress policies supported: Yes
08-18-2010 12:35 PM
Either packet is switched in HW or not is not relevant to QoS policy because QoS policies will be applied before pkt is forwarded to CPU or forwarded in HW.
It is more important that packet is coming to which interface on which module, like SIP or FLEXWAN or LAN Switching module as they have different HW structure and support QoS differently.
If you have only SIP modules with SPAR cards or FLEXWAN cards, then you can use MQC.
With LAN switching modules, CBWFQ/LLQ/CAR/GTS/NBAR are not supported in HW on PFC/DFCand will be processed in SW.
So, it might cause high CPU.
For PFC QoS, enabling mls qos is not enough.
You can read below config guide for more PFC QoS configuration.
KK.
