PfRv3 Internet Edge Load Balancing from Hub Only
BJ
I am trying to determine if it is possible/supported to use PfRv3 only to load balance Internet bound traffic over two ISP links from a hub site. At present, there will be no DMVPN to branches. The primary use-case is to only load balance Internet traffic from what would be identified as the hub site in IWAN terminology. I have a lab configuration using 3 ASR 1001 routers with one MC and to BR routers. The domain is up and requirements are met and I can see load balancing attempting to kick in as I place load on one external interface but I get a message that there are "no channels yet for load balancing".  I do not have any tunnel interfaces configured, aside from the auto-tunnel created by PfR.
LAB-IBR-1#sho domain iwan master status
*** Domain MC Status ***
Master VRF: Global
Instance Type: Hub
Instance id: 0
Operational status: Up
Configured status: Up
Loopback IP Address: 10.1.0.60
Global Config Last Publish status: Peering Success
Smart Probe Profile:
General Monitor:
Packets per burst: 1
Interval(secs): 1
Quick Monitor:
Packets per burst: 20
Interval(secs): 1
Load Balancing:
Admin Status: Enabled
Operational Status: Up
Enterprise top level prefixes configured: 3
Max Calculated Utilization Variance: 626%
Last load balance attempt: 00:00:01 ago
Last Reason: No channels yet for load balancing
Total unbalanced bandwidth:
External links: 6254 Kbps Internet links: 0 Kbps
Route Control: Enabled
Transit Site Affinity: Enabled
95% Bandwidth Check: Enabled
Load Sharing: Enabled
Inter-DC Optimization: Disabled
Connection Keepalive: 10 seconds
Mitigation mode Aggressive: Disabled
Policy threshold variance: 20
Minimum Mask Length Internet: 24
Minimum Mask Length Enterprise: 24
Syslog TCA suppress timer: 180 seconds
Traffic-Class Ageout Timer: 5 minutes
Channel Unreachable Threshold Timer: 4 seconds
Minimum Packet Loss Calculation Threshold: 15 packets
Minimum Bytes Loss Calculation Threshold: 10240 bytes
Maximum Traffic Classes Supported: 160000
Borders:
IP address: 10.1.0.72
Version: 2
Connection status: CONNECTED (Last Updated 18:27:10 ago )
Interfaces configured:
Name: GigabitEthernet0/0/2 | type: external | Service Provider: ISP2 | Status: UP | Zero-SLA: NO | Path of Last Resort: Disabled
Number of default Channels: 0
Tunnel if: Tunnel0
IP address: 10.1.0.71
Version: 2
Connection status: CONNECTED (Last Updated 18:26:40 ago )
Name: GigabitEthernet0/0/2.50 | type: external | Service Provider: ISP1 | Status: UP | Zero-SLA: NO | Path of Last Resort: Disabled
Tunnel if: Tunnel0
It seems that PfRv3 may not be able to support this based on reading I've done and a similar question posted in 2015 at https://community.cisco.com/t5/routing/pfrv3-without-dmvpn/td-p/2738707. Has anyone attempted this or know if this is even possible?
Joseph W. Doherty
Cannot say for certain regarding PfRv3, but I had used OER (basically v.1) to do that for outbound Internet traffic, and had done outbound load balancing, for a L3 "cloud" using both OER and PfR (what would now be early v.2 - before PIRO support). I would expect PfRv3 to able to do so too.
Thanks for the reply. We had a similar setup running on v2 as well but this no longer seems to be possible in v3. All the documentation I can find points to an 'internet-edge' deployment option but I cannot find any examples of this configuration.
