Ping 1941 through non-Cisco router
Greenchris
Hi all,
Apologies for asking what may be an idiot question, but it involves such vague terms that it is difficult to google. Also this might not be entirely a Cisco question, I'm not certain. So I'm sorry if this is inappropriate, or wasting your time.
So apologies out of the way, I have a 1941 router which I'm trying to set up from scratch, working with a Juniper SSG20 firewall (which is also a router). My problem is:
PC1 ---<CAT5>--- 1941 = can ping in both directions
PC1 ---<CAT5>--- JUNIPER ---<CAT5> PC2 = Can ping in both directions
PC1 ---<CAT5>--- JUNIPER ---<CAT5>--- 1941 = Cannot ping
FYI:
PC1 = 192.168.27.201
PC2 = 192.168.32.171
1941 = 192.168.32.81
So hopefully you can see why I'm struggling to "blame" either the 1941 or the Juniper config for this. Its almost like its a combination of the two.
If pinging is all I want to do, what is the difference between a 1941 and a PC? I would have thought nothing, but it seems I might be wrong in this.
Obviously I'm not asking you fine people to comment on the Juniper, but the Juniper seems to be doing its job just fine with everything except the 1941 - of course, any ideas as to how the Juniper might be stopping this working are welcome, but as you see above, it works with a PC. And the Juniper has been working in production for some time, connecting 192.168.27.0, 192.168.32.0 and 192.168.60.0 to the WAN and to each other.
Thanks for taking the time to read this, and a huge thank you to anyone who can suggest any help towards this at all.
Cisco running config is pretty much default, but included here. I won't include the Juniper config as it is really not relevant to discuss on a Cisco forum.
Current configuration : 1334 bytes
version 15.1
hostname ROUTBEAR
boot-start-marker
boot-end-marker
enable secret 5 ###
enable password ###
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
license udi pid CISCO1941/K9 sn ###
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.32.81 255.255.255.0
duplex auto
speed auto
no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password ###
login
transport input all
scheduler allocate 20000 1000
end
6 Replies 6
Jon Marshall
Unless you are doing NAT on the Juniper device the router will need a route ie. -
"ip route 192.168.27.0 255.255.255.0 <Juniper 192.168.32.x IP>"
you could of course use a default route instead.
Jon
Hi Jon, thanks for responding. I could be wrong, but I don't think you've understood the problem, which might be my fault. I have now since "solved" the problem, but now want to understand the issue.
Forget about the outside world for the minute. And think of the Cisco device as the end of the line - I want to send a ping from PC2, which is 192.168.32.171 through the Juniper to the Cisco 1941 which is on 192.168.32.171. The way the Juniper is set, it should just be a switch in this instance, as both devices are on the same network. But I can't ping the PC from the 1941 or vice versa.
Now, it turns out that if I turn on DHCP on the Juniper and issue 192.168.32.81 and 255.255.255.0 the 1941 picks it up and everything works. But if I assign this address and subnet myself, nothing. For the record, the PCs in the scenario described above are all static IPs.
Does anyone know what I'm missing here?
Okay your original description talked about the ping from PC1 which is on a different subnet.
Now I understand it is indeed weird.
So the PCs did not use DHCP but were static and it worked fine ?
If so can you on the router do "no ip routing", then assign the IP statically and see what happens. Obviously you don't need a default gateway as they are on the same IP subnet.
Not sure it will make any difference but worth a try.
Jon
Hold on, I think I've screwed something up here in my explanation. In my previous post I said that PC2 and the Cisco 1941 both had the same IP address, this is not true. The root problem is still there and still the same, but I need to explain properly.
Let me knock something up in Visio which explains the situation better. Thanks for your time, it is appreciated.
AAAAARGH!! The DHCP was assigning a gateway, and I wasn't! PROBLEM SOLVED!! I told you it was just me being an idiot... :-)
However, since I went through the below, I might as well post it in the vain hope that one day it helps another idiot. Jon, thanks for your help.
OK, so this is the actual setup.
Orange arrows are physical Cat5 cables, Blue/Green is just to show subnets, White are dumb switches
But I don't want to over-complicate things. To be clear:
NARWHAL can ping BEAR and vice versa. Narwhal is DHCP. Bear is static. But I have changed these to static/DHCP with no effect (as it should be). It is irrelevant to the current discussion, but both of these can also ping the WAN - I am writing this on NARWHAL. That plus months of day to day use in production should (hopefully) eliminate Juniper routing from the equation.
I'll put in exactly what I do on the 1941 to be as clear as possible.
1941 commands:
conf ter
int GigabitEthernet 0/1
ip address 192.168.32.99 255.255.255.0
end
ping 192.168.32.11 --- SUCCESS
ping 192.168.27.201 --- FAIL
ping 8.8.8.8 --- FAIL
Then:
conf ter
no ip address
ip address dhcp
end
(wait for DHCP assign - 2-3 seconds)
ping 192.168.27.201 --- SUCCESS
ping 8.8.8.8 --- SUCCESS
The DHCP server inside Juniper is assigning ONLY IP and netmask...
(This is the point where I went to check that statement, discovered the gateway and facepalmed so hard it hurt...)
So it was the default gateway after all.
Makes perfect sense :)
Jon
