PING Help
rpfinneran
Anybody know what "M" means?
Router#ping 10.0.0.1 si 1500 df
Sending 5, 1500-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Packet sent with the DF bit set
M.M.M
Success rate is 0 percent (0/5)
rpfinneran
Found the answer...
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6057.shtml
It means the local device needs to fragment, but df bit set. You will only see this if the device originating the ping is the device that must fragment.
