ping source not working when using route-map
Frank Sinatra
I have two active WAN connetions so I have a route-map for each connection. If I connect a PC to the LAN, everything works fine. But ping doesn't work with a source. If I do ping 8.8.8.8 source vlan 10, it doesn't work.
Here's my config:
interface FastEthernet0
 switchport access vlan 2
interface FastEthernet1
 switchport mode trunk
interface FastEthernet2
 switchport access vlan 3
interface Vlan2
 description WAN-1
 ip address 192.168.10.2 255.255.255.252
interface Vlan3
 description WAN-2
 ip address 192.168.20.2 255.255.255.252
 ip nat outside
interface Vlan10
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
 ip policy route-map PBR-10
interface Vlan20
 ip address 10.10.20.1 255.255.255.0
 ip nat inside
 ip policy route-map PBR-20
ip nat inside source list Vlan10 interface Vlan2 overload
ip nat inside source list Vlan20 interface Vlan3 overload
ip access-list extended Vlan10
permit ip 10.10.10.0 0.0.0.255 any
ip access-list extended Vlan20
permit ip 10.10.20.0 0.0.0.255 any
! route-map PBR-10 permit 10 set ip default next-hop 192.168.10.1 ! route-map PBR-20 permit 10 set ip default next-hop 192.168.20.1 !
Philip D'Ath
Meraki Community All-Star
Policy based routing only affects traffic flowing through the router.
You have to enable "Local Policy Based Routing" for it to affect traffic originating from the router.
https://www.grandmetric.com/knowledge-base/design_and_configure/how-to-configure-policy-based-routing-for-localy-generated-traffic-cisco/
7 Replies 7
balaji.bandi
If i undertstand correctly your PBR is not covered VLAN 10 ?
Do you haver NAT ? can you post full config ?
BB
Sorry! I have updated my original post with NAT config.
Do you have Default route ?
show you post show ip route ?
BB
I had a default route for the WAN-1 but it was causing issues so I have removed it now.
C        10.10.10.0/24 is directly connected, Vlan10
L        10.10.10.1/32 is directly connected, Vlan10
C        10.10.20.0/24 is directly connected, Vlan20
L        10.10.20.1/32 is directly connected, Vlan20
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, Vlan2
L        192.168.10.1/32 is directly connected, Vlan2
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.20.0/24 is directly connected, Vlan3
L        192.168.20.1/32 is directly connected, Vlan3
So you need to have Default route, But if that is breaking the connection
show us the issue after adding route. so we can have look and suggest best option.
BB
Philip D'Ath
Hello
Vlan 2 isnt enabled for nat also your PBR statement could be incorrect here.
ip default nexthop will only be use if no match is made in the route tablble, and also if only a default route is match then it will be ignored anyway and routed normally.
I think you need to try and use ip default-next hop instead which will try to policy route with no rib check.
Try the following:
conf t
no ip nat inside source list Vlan10 interface Vlan2 overload
no ip nat inside source list Vlan20 interface Vlan3 overload
interface Vlan2
ip nat outside
match interface vlan 10
match ip address vlan 10
no set ip default next-hop 192.168.10.1
route-map PBR-20
match interface vlan 20
match ip address vlan 20
no set ip default next-hop 192.168.20.1
set ip next-hop 192.168.20.1
ip route 0.0.0.0 0.0.0.0 vlan 2 192.168.10.1
ip nat inside source route-map PBR-10 interface Vlan2 overload
ip nat inside source route-map PBR-20 interface Vlan3 overload
Kind Regards
Paul
