Ping Sweep on Router
davidhuynh5
Is there a way to perform a ping sweep of an entire subnet on a router without using a third party utilitiy?
Thanks in advance.
2 Accepted Solutions
gatlin007
Level 4
Level 4
If the goal of the ping sweep is to see all the hosts on a particular subnet then the router arp table is a valuable resource.
Ping the broadcast address; then view the arp table.  For example if the subnet in question is 192.168.1.0/24; then ping 192.168.1.255 from the router.  Then execute a
show arp | inc
  The results should be all mac/IP addresses on that subnet.
Chris
Jerry Ye
You can try a TCL script like the following. Assuming your network is 10.1.1.0/24 (.1-.254)
tclsh
for {set i 1} {$i <= 254} {incr i} {
set var 10.1.1.
append var $i
ping $var rep 3 time 1}
ROUTER(tcl)#tclquit
Remember to use tclquit to exit the TCL prompt.
HTH,
jerry
gatlin007
Level 4
Level 4
show arp | inc
Chris
Jerry Ye
tclsh
set var 10.1.1.
append var $i
ROUTER(tcl)#tclquit
HTH,
jerry
