Ping works but no Internet, please help
Safar Safarov
Hello All,
So I configured my 2821 in my test lab and faced with the following issue:
I have 5 PCs in my test lab.
I can ping & pathping (tracert) any ip address/website from all PCs and router.
I can access internet only on 1 PC, I get 404 error both on IE and Firefox on others, so I think may be I missed smth in config...
You may see the config below:
! Last configuration change at 12:23:02 BKD Sun Jun 6 2010 by xxxxx
! NVRAM config last updated at 12:38:07 BKD Sun Jun 6 2010 by xxxxx
version 12.4
hostname TEST-ROUTER
boot-start-marker
boot system flash c2800nm-advsecurityk9-mz124-22.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone BKU 4
clock summer-time BKD recurring last Sun Mar 2:00 last Sun Oct 3:00
dot11 syslog
ip source-route
ip cef
ip name-server xx.xx.xx.21
ip name-server xx.xx.xx.22
username xxxxx privilege 15 secret 5 $x1$xaASO$m6ZS6iTjRxWxCt2mWY9Rx1rzQ0tO53.
archive
log config
hidekeys
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
shutdown
interface FastEthernet1/4
shutdown
interface FastEthernet1/5
shutdown
interface FastEthernet1/6
shutdown
interface FastEthernet1/7
shutdown
interface FastEthernet1/8
shutdown
interface FastEthernet1/9
shutdown
interface FastEthernet1/10
shutdown
interface FastEthernet1/11
shutdown
interface FastEthernet1/12
shutdown
interface FastEthernet1/13
shutdown
interface FastEthernet1/14
shutdown
interface FastEthernet1/15
shutdown
interface Vlan1
ip address yy.yy.yy.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ip policy route-map TEST-iNET
no mop enabled
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname ZZZZZZ
ppp chap password 0 ZZZZZZ
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool GPOOL xx.xx.xx.145 xx.xx.xx.150 netmask 255.255.255.248
ip nat inside source list NAT-POOL pool GPOOL overload
ip access-list standard NAT-POOL
permit yy.yy.yy.0 0.255.255.255
route-map TEST-iNET permit 10
match ip address NAT-POOL
set interface Dialer1
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
scheduler allocate 20000 1000
ntp master
ntp server ww.ww.ww.132
ntp server ww.ww.ww.139
end
Your help is appreciated.
Thank you.
Safar Safarov
Adding
mtu 1492
ip tcp adjust-mss 1452
to interface Dialer1 has solved the problem.
Thanks.
