Pining between devices is not working
jushb001
Hi, im having issues pining between devices, i also cannot figure out how to connect the D1 switch and R1 router. Password for secret is class and normal password is cisco. Would appreciate any help or guidance! thank you !!
Mark Elsen
       - FYI : Community group for Packet Tracer project questions
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
piruu91
Hi @jushb001,
Had a quick look at your lab and there are a couple of things I noticed:
1. R1 interface was admin shut and no IP assigned to it
2. on D1, you assigned an IP to one one the switch interfaces. In order to allow routing between these devices you would need to assign the 10.0.255.x subnet to a vlan (Vlan 1 would do)
3. on D1 I noticed that Vlan 1 was also admin shut, so Vlan routing will not work until you do a no shut.
Apologies if I missed anything but I had a really quick look.
Kind regards,
Joao
