PIX/Router and routing protocols
rasoftware
Does anyone know if its possible to get a PIX to advertise the route created by adding tunnels via RIP/OSPF to a inside router?
Basically I have a router as a gateway on the LAN (192.168.1.1), some network connect via PIXA (192.168.1.2) and some via PIXB (192.168.1.3). I have to manually add routes to the LAN router to each network via which ever PIX. I would like the PIX to advertise the network accessible by the tunnels back to the router so I don't need make sure the statics are correct. There are many many tunnel on each so a lot of static routes even with summerisation which is not alway appropriate.
thomas.chen
Level 6
Level 6
No, as far as I know, it is not possible to get a PIX to advertise the route created by adding tunnels via RIP/OSPF to a inside router
