PLATFORM-1-CRASHED
Victoriano Jr Cangrejo
Community Member
Can somebody explain to me why this is happening in a stack switch?
Aug 23 07:39:53.295 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Aug 23 07:39:53.505 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/22, changed state to up
Aug 23 07:39:53.757 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/19, changed state to up
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: System previously crashed with the following message: (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1) (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Copyright (c) 1986-2007 by Cisco Systems, Inc. (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Compiled Fri 20-Jul-07 01:58 by nachen (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED:   (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Machine Check Exception (0x0200)! (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: ESR: 0x00000000, BESRA: 0x00000000, BESRB: 0x00000000, BEAR: 0x00000000 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: CPU Register Context: (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Vector = 0x00000200  PC = 0x0117CB78  MSR = 0x00029230  CR = 0x90000009 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: LR = 0x0117CB8C  CTR = 0x006D6494  XER = 0xC0000053 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: R0 = 0x02652EFC  R1 = 0x02526720  R2 = 0x00000000  R3 = 0xFFFFFFFF (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: R4 = 0xFFFFDECF  R5 = 0x00000032  R6 = 0x02525058  R7 = 0x00000006 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: R8 = 0x00029230  R9 = 0x01E5EFC8  R10 = 0xA6EA5A99  R11 = 0x037BA798 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: R12 = 0xA6EA3968  R13 = 0x00110000  R14 = 0x00313A5C  R15 = 0x00000000 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19 = 0x00000000 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23 = 0x00000000 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: R24 = 0x00000000  R25 = 0x00000006  R26 = 0x00000001  R27 = 0x00000000 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: R28 = 0x01E5EFC8  R29 = 0x037BA798  R30 = 0x0252692C  R31 = 0x02196AA0 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Stack trace: (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: PC = 0x0117CB78, SP = 0x02526720 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Frame 00: SP = 0x02526758    PC = 0x025515C8 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Frame 01: SP = 0x02526760    PC = 0x0117CE60 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Frame 02: SP = 0x02526780    PC = 0x0117CF80 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.487 UTC: %PLATFORM-1-CRASHED: Frame 03: SP = 0x02526798    PC = 0x011C27A0 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.496 UTC: %PLATFORM-1-CRASHED: Frame 04: SP = 0x025267B8    PC = 0x00313AA8 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.496 UTC: %PLATFORM-1-CRASHED: Frame 05: SP = 0x025267C0    PC = 0x009A5850 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.496 UTC: %PLATFORM-1-CRASHED: Frame 06: SP = 0x00000000    PC = 0x0099CE24 (C2-U1-E005-3750-101-B-1)
Aug 23 07:40:46.496 UTC: %PLATFORM-1-CRASHED:   (C2-U1-E005-3750-101-B-1)
5 Replies 5
Leo Laohoo
Upgrade your switch from this ancient IOS to something more recent (and stable), like 12.2(55)SE8.
Can you provide me the link to down load this latest IOS version.
Vignesh Rajendran Praveen
Hi Victoriano,
Based on decoding the above error logs I can confirm that the device is continously crashing due to a hardware related issue. And in order to resolve the same, you need to replace (RMA) the device as early as possible.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
I am also having a similar issue with a 3560X that crashes every 5 weeks (almost to the hour). It is running 15.0(2)SE2. How were you able to decode the crash file?
Danny
Hi Danny,
We are still planning to upgrade the IOS to the latest version. So i cant give any advice to you this time until we done it.
