Please help - with switch and access point setup
richrmann
I have been thrown into this and need help. How do I set this up so everyone can access the internet access?
I have the following hardware
Optonline Cable Modem with static ip, SRW2016 gigabit switch, Befw11s4 v3.2 Wireless Access Point Router with 4-Port Switch, 5 PC's Wired and 10 laptops wireless.
vassiliev
see this topology:
[Modem]
[W-Router]~~Wirless~~Laptops
[SRW2016]
Please set ip on your Linksys router WAN interface, or PC GW is Linksys router LAN IP....
Thank you for your assistance, could you please take a look at the diag below.
Currently they have the modem feeding into the switch and then a cat6 running to another building where the wireless access point is located. The access point is set to static ip with the info from the isp. Only one laptop can have internet service at a time.
please advise how access point should be setup so that it will serve ip's to the laptops.
Again many thank!
Building 1 Building 2
|----------|______|---------|
|It closet |______| Shop |
I have in building 1 the modem & switch and wired pc's (cat6).
I have in building 2 the workshop where I need to provide wireless service to the laptops.
