poe log messages on a 857
arunjangid
hi all,
i have noticed poe log messages in my cisco 857 router, looking around there is mention of a cosmetic ios bug pertaining to 877 router but not the 857.
BUG - CSCsd68389.  any suggestions as to why i am getting these errors on my 857?
001586: Oct  5 11:25:06.499 NZST: esw_dtc_ltc4258_reg_write: no acknowlege from POE
001587: Oct  5 11:25:06.499 NZST: esw_mrvl_pdc_hardware_config failed on slot 0/0
001601: Oct  5 13:06:29.879 NZST: esw_dtc_ltc4258_reg_write: no acknowlege from POE
001602: Oct  5 13:06:29.879 NZST: esw_mrvl_pdc_hardware_config failed on slot 0/0
001603: Oct  5 13:06:31.387 NZST: esw_dtc_ltc4258_reg_write: no acknowlege from POE
001604: Oct  5 13:06:31.387 NZST: esw_mrvl_pdc_hardware_config failed on slot 0/0
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(9)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 17-Jun-06 04:43 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
myrtr uptime is 1 week, 2 hours, 57 minutes
System returned to ROM by reload at 11:03:16 NZST Fri Sep 28 2012
System restarted at 11:03:54 NZST Fri Sep 28 2012
System image file is "flash:c850-advsecurityk9-mz.124-9.T.bin"
Cisco 857 (MPC8272) processor (revision 0x200) with 59392K/6144K bytes of memory.
Processor board ID FHK102120HB
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
singhaam007
Level 3
Level 3
it seems to when when no POE module installed.
http://www.dslreports.com/forum/r21510313-LAN-error
https://supportforums.cisco.com/thread/188382
hope this will help.
thanks
Sandeep Choudhary
Hi Arun,
Try this:
these messages are related to the Power-over-Ethernet (PoE) module. Are you using one?
If  you use the PoE module, connect all four Ethernet cables on the PoE  module to the four LAN Ethernet ports on the Cisco router.(It  is important to connect ALL FOUR Ethernet cables).
To  ensure proper PoE module operation, first connect ALL 4 cables to the  switch ports. Then, apply power to the PoE module. Do not connect the  PoE module power supply to the PoE module before you connect the PoE  module to the router.
or
Step1: Check the cables connection.
Step2: If all are ok then see the POE module(U hv POE module installed ?)
Step3: If still this problem Exists then u have problem with IOS.
similer problem links given by Amrinder, please see and try to solve the issue!
Please rate if it helps.
arunjangid
sorry i didnt mention in the orignal question, that i am not using a POE module. Checked ethernet cables, looked to be plugged in alright. but still am getting these messages. got some today morning.
002119: Oct  8 06:39:37.674 NZST: esw_dtc_ltc4258_reg_write: no acknowlege from POE
002120: Oct  8 06:39:37.674 NZST: esw_mrvl_pdc_hardware_config failed on slot 0/0
002121: Oct  8 06:39:39.182 NZST: esw_dtc_ltc4258_reg_write: no acknowlege from POE
002122: Oct  8 06:39:39.182 NZST: esw_mrvl_pdc_hardware_config failed on slot 0/0
