POE support in Catalyst C6807-XL?
mreinoso
Its possible to configure any card in a C6807-XL which support PoE?
Thanks in advance and regards
Leo Laohoo
If you want a line card that supports PoE for the 6807XL then look at the 6800IA-48FPD.
thanks Leo for your quick answer. The problem is that que customer want to buy a chassis ...
