Point-to-Point Configuration
dacruzer1
Hello Everyone,
I am about to install a CISCO 2811 router for a point to point connectivity using the serial port.  Can someone take a look at it and see if there is anyhting I need to add or delete.  Thanks much.  It is going to be a T-1 connection.
Building configuration...
Current configuration : 3964 bytes
version 12.4
service password-encryption
hostname Goodsprings
boot-start-marker
boot-end-marker
card type t1 0 2
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone pst -8
clock summer-time pdt recurring
no network-clock-participate wic 2
no ip source-route
ip cef
no ip domain lookup
controller T1 0/2/0
framing esf
linecode b8zs
cablelength long 0db
channel-group 1 timeslots 1-24
ip ssh authentication-retries 2
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
shutdown
interface FastEthernet0/1/7
shutdown
interface FastEthernet0/1/8
shutdown
interface Serial0/2/0:1
ip address 192.168.161.58 255.255.255.252
encapsulation ppp
ip route-cache flow
no fair-queue
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip directed-broadcast 17
router eigrp 100
network 192.168.161.56 0.0.0.3
network 10.10.10.0
no auto-summary
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
l
scheduler allocate 20000 1000
end
5 Replies 5
Reza Sharifi
I think, you have configured most of the parameters.  You also need to add clock sorce
Enabling the T1 CSU WIC
The following are prerequisites to enable the T1 CSU WIC:
Leased line from your telephone company
Configuration  parameters depending on your specific telephone company. For most  connections, the default settings should suffice:
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 timeslots all speed 64
service-module t1 framing esf
service-module t1 lbo none
service-module t1 linecode b8zs
no service-module t1 remote-alarm-enable
no service-module t1 fdl
http://www.cisco.com/en/US/docs/ios/12_2/interface/configuration/guide/icfserin.html
Thank you very much Mr. Reza, concerning the clock source, per our TelCo they said that their equipment will be sourcing the clock.
Ok, if telco is sourcing the clock then that is fine.  You can also configure the parameters directly under the main interface without a sub-interface.
Mr Reza,
Are you talking about the serial interface ?
Alfred
yes,
