Police and Priority with bandwidth/percent are not allowed in the same class
Hi Team,
I am replacing a 7204VXR Router with an ASR1002-X Router running IOS-XE 3.7.5S
When it comes to configure QoS for a traffic class, I am getting the below error when configuring the priority and police commands:
"Police and Priority with bandwidth/percent are not allowed in the same class"
This is what I'd like to implement:
policy-map EMEA_Outbound
class Out_Shaper_Traffic_A
  priority 4608
    police 4608000 conform-action transmit  exceed-action set-dscp-transmit af41 violate-action set-dscp-transmit af41
The intent is to reserve 4608 for Traffic_A and to re-mark it as AF41 when it exceeds the limit, that is to ensure that our provider does not drop it when we fill their QoS class, thus I want to remark it to another class.
However the Router IOS does not seem to support both commands any longer.
Any hints on how we could solve or bypass this?
2 Accepted Solutions
Hello, Ruggero.
Just use priority statement without any numeric value and keep your policer.
PS: before changing the policy, I would detach it from interface!
Two more comments:
I would rewrite the statement
class Out_Shaper_Heartbeat
  set dscp ef
  priority
  police rate 1024000
as
 priority level 1
  police rate 1024000
   conform-action set-dscp-transmit ef
At the same time you need to understand, that even though you remark traffic to af41, it stays in priority queue, so it might impact the link if too much traffic matches the class! It's recommended to have drop action!
In this case I would tweak bc/be and configure violate action as drop.
22 Replies 22
Hello, Ruggero.
Hi Vasilii,
That's absolutely correct, it worked sweet and I just faced a second issue with QoS moving from the 7204VXR platform to ASR1002-X IOS-XE.
I have a policy that needs to use the priority command on two different classes inside the same polic-map and the IOS-XE does no longer allow to use two priority commands within the same policy-map.
Would you have any workaround for that too?
Here is what I need to accomplish:
 description Nike Voice and Data Policy for EMEA.
 class Out_Shaper_internet
  bandwidth remaining percent 10
 class Out_Shaper_intranet
  bandwidth remaining percent 15
class Out_Shaper_ms-shares
  bandwidth remaining percent 8
  shape average percent 50
 class Out_Shaper_ftp
  bandwidth remaining percent 3
 class Out_Shaper_smtp
 class Out_Shaper_citrix
  bandwidth remaining percent 2
 class Out_Shaper_blackberry
  bandwidth remaining percent 4
 class Out_Shaper_RTP-Voice
  priority
  police rate 3890000
  set dscp ef
  set dscp ef
  priority
  police rate 1024000
 class Out_Shaper_Video
 class class-default
  fair-queue
  random-detect
  set dscp default
As soon as I try to apply the second priority to the class, it states that two priorities are not allowed within the same policy-map.
I had this running for years and all of a sudden we can't implement it anymore, that's a bummer.
Hello.
In this case you can use "priority level 1" and "priority level 2" (you can't have multiple classes with equal level under single policy).
PS: level 1 has higher priority then level 2.
Hey Vasilii,
Since you are a Guru here :) maybe you can clarify a doubt too on QoS:
On the 7204VXR I used to have a global nested policy-map with shape-average and bandwidth commands applied:
policy-map EMEA_MPLS_Outbound_Shaper
 description EMEA Policy for MPLS QoS outbound
 class Site1  shape average 10000000
  bandwidth 10000
  service-policy EMEA_Outbound_Site1
 class Site2
  shape average 1984000
  bandwidth 1984
  service-policy EMEA_Outbound_Site2
 class Site3
  shape average 4096000
  bandwidth 4096
  service-policy EMEA_Outbound_Site3
The policy-map is applied to a 100Mb interface on an hub site that serves different spoke sites, thus the need to have a QoS class different for each site.
Shape-average was used to limit the traffic to the remote site to not exceed more than the remote site BW
Bandwidth statement was to allow the child service-policy to have a BW in reference when using the "bandwidth remaining percent X" command.
So for example if "service-policy EMEA_Outbound_Site1" has different classes like HTTP bandwidth remainin percent 10, ms-share 5% etc etc the bandwidth statement was allowing the Router to calculate how much 10% it needed to take for HTTP traffic.
For example on Site1 I use bandwidth 10000 which is 10Mb and the child policy "service-policy EMEA_Outbound_Site1" was able to calculate bandwidth remaining percent for the HTTP class at 10% of 10Mb.
However now that I upgraded to ASR1002-X the Router does not allow to apply the child policy-maps if I use the bandwidth command:
Here is an example of what happens:
Router(config)#policy-map EMEA_MPLS_Outbound_Shaper
Router(config-pmap)# class Site1
Router(config-pmap-c)#  shape average 10000000
Router(config-pmap-c)#  bandwidth 10000
Router(config-pmap-c)#  service-policy EMEA_Outbound_Site1
Policy EMEA_Outbound_Site1 attached to class with bandwidth kbps or perc configured is not supported
% service-policy EMEA_Outbound_Site1 of type default is not allowed in policy-map EMEA_MPLS_Outbound_Shaper of type default
I wonder if I remove the Bandwidth command out of each class, how will the router know that I need to reserve 10% of 10Mb for the HTTP traffic on Site1 if it does not know the Bandwidth of Site1? Is it now going to refer to the Internface BW 100Mb in which I apply the global-pmap?
That would be a bummer because it would screw up the purpose of running nested QoS policies and it would end up reserving 10% of 100Mb for HTTP traffic on Site1 which has a shape-average max pipe of 10Mb.
This is how the child service-policy looks like in case you wonder:
policy-map EMEA_Outbound_Site1
 class Out_Shaper_Riverbed
  priority 128
 class class-default
  fair-queue
  random-detect
  set dscp default
Hello, Ruggero.
I'm not sure about ASR behavior in this case, but I think you may remove bandwidth from classes SiteX, as shaper's CIR would make child policies aware of available bandwidth. To check the values try "sh policy-map int ... out".
At the same time if you have no bandwidth assigned to classes SiteX, I'm not sure how scheduling will work.
PS: I'll try to review ASR's QoS model.
I've tried sh policy-map int before, in some IOSs it used to reveal how much Bandwidth remaining percent it is able to calculate for each class in KBPS, however in the IOS-XE it just shows that I've applied the commands bandwidth remaining percent without showing how much BW is being calculated. I've currently shut the router down as they make too much noise in the lab. I'll turn them up later in the afternoon and paste the show policy-map output.
Hello, Ruggero.
Could you please hint me where have learnt about this nested-policy design? I'm not familiar with it and I couldn't find it in any design guides.
PS: ASR 1000 design might be found at http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Video/qoswanaggasraag.html (take a look at QoS design 4.0)
Hi Vasilii,
I've created this design by myself 4 years ago, I haven't looked at anywhere on the Internet, I just based it on the commands I had available at that time using a Hierarchical Nested policies, and it worked good until I migrated to the new IOS-XE.
Hello, Ruggero.
I saw similar design a couple of times; but the only business reason I could imagine is poor QoS model on ISP side.
I'm looking for design guide[s], that could shed the light on the underlying requirements.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I thought starting with HQF, child policies would pick up the bandwidth of the parent's (class) shaper.
Have you tried the policy w/o the parent class bandwidth statements?
PS:
Having a parent class per remote, makes sense, but each remote has its own (different?) child policy?
BTW, I wouldn't recommend using both FQ and WRED in class-default.  (Actually I usually recommend against using WRED if FQ is available.  Also if FQ is supported in non-default classes, I often recommend using it there too.)
Lastly, FQ in class-default might negate the need for many or even all your non-LLQ classes.  Or, you might find a tiered set of classes, each with FQ, works well.
e.g.
policy-map Tiered
class LLQ
priority percent 33
class foreground
bandwidth remaining percent 81
fair-queue
class background
fair-queue
class class-default
bandwidth remaining percent 9
In the above Tiered you allow most traffic to just go to class-default and allow FQ to deal with it.  If you have some traffic that really needs extra priority, perhaps such as your Citrix (although I would exclude Citrix printing and disk-to-disk copying) might be directed to foreground class.  Known bandwidth consumers, such as FTP, might be directed to background class.
Apart from the FQ subject, you mean that in my policy the child policy should be able to calculate the BW via the shape average command that is setup in the parent? If that's the case then I am good and I should not do anything else to correct the configuration.
Disclaimer
Posting
from: http://www.cisco.com/c/en/us/td/docs/ios/qos/configuration/guide/convert/qos_hrhqf/qos_frhqf_support.pdf
Nested Policy and Reference Bandwidth for Child-Policy
In HQF when you configure a nested policy with a child queueing policy under a parent shaping class, the reference bandwidth for the child queueing policy is taken from the following: minimum (parent shaper rate, parent class's implicit/explicit bandwidth guarantee).
I think the above means child will use either the parent's shaper rate or class bandwidth.
Right, that's what I expect it to happen, in such case I should be safe to keep the shape-average on the parent and let the child use it to calculate the % bandwidth of the individial classes. I'll run some traffic over the router next week and see how it behaves. Tks.
Two more comments:
  set dscp ef
  priority
  police rate 1024000
as
 priority level 1
  police rate 1024000
