Policing in QOS
wrobbin
Currently i am having an issue where it seems like my Policing is not working correctly. I am using this on a input policy from My LAN to My WAN. What happens is the servers that match that ACL are only allow a certain about of bandwidth to push out updates to our remote sites but when they do push it bring those remotes site to a crawl. So is the policing total amout per interface or per flow ? ANy aisstance you could provide would be most helpful.
class-map match-all WINUP
match access-group 157
policy-map MARK-APPS
class VOICE-TRAFFIC
  set ip dscp ef
class MISSION-CRITICAL-TRAFFIC
  set ip dscp af31
class CALL-SIGNALING-TRAFFIC
  set ip dscp cs3
class ROUTING-TRAFFIC
  set ip dscp cs6
class TRANSACTIONAL-DATA-TRAFFIC
  set ip dscp af32
class WINUP
   police cir 750000
     conform-action transmit
     exceed-action drop
class BULK-DATA-TRAFFIC
  set ip dscp af21
class NETWORK-MANAGEMENT-TRAFFIC
  set ip dscp af22
class Interactive-Video-Traffic
  set ip dscp af41
sh policy-map MARK-APPS
  Policy Map MARK-APPS
    Class VOICE-TRAFFIC
      set ip dscp ef
    Class MISSION-CRITICAL-TRAFFIC
      set ip dscp af31
    Class CALL-SIGNALING-TRAFFIC
      set ip dscp cs3
    Class ROUTING-TRAFFIC
      set ip dscp cs6
    Class TRANSACTIONAL-DATA-TRAFFIC
      set ip dscp af32
    Class WINUP
     police cir 750000 bc 23437
       exceed-action drop
    Class BULK-DATA-TRAFFIC
      set ip dscp af21
    Class NETWORK-MANAGEMENT-TRAFFIC
      set ip dscp af22
    Class Interactive-Video-Traffic
      set ip dscp af41
interface GigabitEthernet0/2
  ip accounting output-packets
load-interval 30
delay 100000
duplex full
speed 1000
media-type rj45
no negotiation auto
service-policy input MARK-APPS
gatlin007
Level 4
Level 4
In this example it would not police per-flow.  It would police all traffic matching the class WINUP to 750Kbps.  You may want to investigate micro-flow policing on the downstream switch.
This link has some good micro-flow info:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c8c4b.shtml
Chris
i didnt want to do per flow just wondering why we had a policer on that interface and it doesnt seem to be working right ...casue when those servers start a push they kill some of out remote sites the ACL its maps to is an Extended IP host ACL so it should cover all ports.it is also placed high in the policy
When the problem is occurring try a 'show policy-map interface g0/2'.  This should give you and indication if the traffic in question is being matched by the WINUP class.
Chris
