Policing over wan cloud
hanwucisco
We have a WAN cloud, many of the connection subscribed as 10m, with 256k burst buffer. the traffic exceeds it. Verizon recommanded us to do shaping. but their words are so general. it said, "we recommed you configure 85-90% of the 10M, and leave the buffer bigger"
====L3 interafce(main site, with subinterfaces for remote sites' connection)-------(Verizon cloud)----L3interface (remote site, with sub-interfaces configured for local vlans, for main site connection)
My question for you are,
1. on which interface should i apply the policy? subinterfaces? or the physical interfaces?
2. what is the command should look like?
thanks,
Han
hanwucisco
I am adding the relevant configs on one of the remote sites,
Remote_2811Rtr#sh ip int bri | e una
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0.21         10.X.96.1      YES NVRAM  up                    up
FastEthernet0/0.22         10.X.97.1      YES NVRAM  up                    up
FastEthernet0/0.23         10.X.98.1      YES NVRAM  up                    up
FastEthernet0/0.24         10.X.99.1      YES NVRAM  up                    up
FastEthernet0/1.2036       10.Y.240.26    YES NVRAM  up                    up
FastEthernet0/1.2050       10.Y.242.26    YES NVRAM  up                    up
Remote_2811Rtr#sh run int fa0/1.2036
Building configuration...
Current configuration : 185 bytes
interface FastEthernet0/1.2036
description "HQ Ave EVC" VLAN 2036
encapsulation dot1Q 2036
ip address 10.Y.240.26 255.255.255.252
ip flow ingress
ip flow egress
delay 1
end
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Unclear what your logical and physical topologies are.  Also need specifics on device type(s) and IOS versions.  Could you further explain?  For example . . .
Physical bandwidth at HQ is?  One VLAN per remote branch?  HQ<>branch VLAN logically p2p?  Physical bandwidth at branch?  Any logical bandwidth cap between HQ<>branch?  Device type(s)?  IOS version on device type(s)?
