Policy Based Routing on ASR1006
tfbissett
I have run PRB on multiple Cisco router 2800, 3800, 6500 etc. We use it for redircting to a WAN Accelerator. We setup the ASR the same as all our other with a route-map and an match criteria of an ACL and added the "ip policy route-map" statement to the LAN side interface, no traffic is hitting the ACL, upgraded to the latest software on the ASR 12.2(33)XNB2. I ahve also tried using WCCP with similar ACL's will not work either. Has anyone come across this issue?
Thanks Tom
Laurent Aubert
ACL counting when used for PBR is not supported on the ASR. But the PBR feature is working and supported starting XNB
Laurent.
Laurent Aubert
Laurent.
Thanks for the answer!
