Policy Based Routing - PBR - where to add on a Router on a stick
Ranbeckycr_2
Hi Experts,
I want to change my routing. I want to send all the traffic ORIGINATING from the
192.168.10.x network to go out thru my ISP  gateway 200.1.1.1, and then add a default
route for my 192.168.2.0.
I do not know where to apply the policy route since I am using Router on a STICK.
Should I apply it to each sub interface or to the interface Fa0/0:
In example:
interface FastEthernet0/1.1
interface FastEthernet0/1.2
--- Route map configuration to apply (I think) ---
route-map Router permit 10
description Sends network traffic 192.168.10.
match ip address 101
set ip next-hop 200.1.1.1
route-map Router permit 20
description allow other network traffic
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
no ip route 0.0.0.0 0.0.0.0 200.1.1.1
ip route 0.0.0.0 0.0.0.0 192.168.2.1  (my new gateway)
no ip route 192.168.2.0 255.255.254.0 192.168.2.1
Actual Running  configuration:
Router(config)#do sh run
version 12.4
hostname Router
interface FastEthernet0/0
description outside
ip address dhcp client-id FastEthernet0/0
ip access-group outside in
ip nat outside
description inside
no ip address
encapsulation dot1Q 1 native
ip address 192.168.2.115 255.255.254.0
ip nat inside
encapsulation dot1Q 2
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip classless
ip nat inside source static tcp 192.168.2.33 80 200.1.1.10 80 extendable
ip nat inside source static tcp 192.168.10.245 5015 200.1.1.10 5015 extendable
ip nat inside source static tcp 192.168.10.246 5016 200.1.1.10 5016 extendable
ip access-list extended outside
permit tcp any host 200.1.1.10 eq www
permit udp X.Y.Z.0 0.0.0.255 any eq bootpc
permit udp any host 255.255.255.255 eq bootps
permit udp any any eq bootpc
permit tcp any host 200.1.1.10 eq 5015
permit tcp any host 200.1.1.10 eq 5016
access-list 12 permit 192.168.2.0 0.0.0.255
Router(config)#
Router(config)#do sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            200.1.1.10    YES DHCP   up                    up
FastEthernet0/1            unassigned      YES NVRAM  up                    up
FastEthernet0/1.1          192.168.2.115    YES NVRAM  up                    up
FastEthernet0/1.2          192.168.10.1     YES NVRAM  up                    up
2 Accepted Solutions
    Just apply it on the interface that PBR traffic is coming in to the router.  It should be FastEthernet0/1.2.
HTH,
Toshi
The answer is in your description .you apply PBR policy where 192.168.10.x is configured which is your fasteth0/1.2
Kishore
5 Replies 5
HTH,
Toshi
Kishore
Kishore, perhaps you don't know it but you have helped me twice already!  Thanks a bunch.
Hi Randall. Firstly thanks for your rating and kind words. i am glad I could be of help and will continue to do so
