1841 SSH Access under ZBFW
IM-Design
Im unable to access my newly configured 1841 via SSH or via CCP from the WAN side.
Is there anything I can do from the LAN side in CCP that will assure that this router is able to be managed from the WAN?
TIA
3 Accepted Solutions
hi charles,
there are some missing lines for CCP and SSH. kindly temporarily removed your ZBFW while testing this out.
CCP:
username administrator privilege 15 secret
ip http authentication local
SSH:
crypto key generate rsa
ip ssh time-out
ip ssh authentication-retries
int f0/0
no zone-member security out-zone
int f0/1
int vl1
no zone-member security in-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
policy-map type inspect ccp-permit
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  drop
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
This is why you can't access your router with ssh or CCP because you are only permitting DHCP replies to get an ip address but nothing else so to remedy do this:
no service-policy type inspect ccp-permit
zone-pair security ccp-zp-self-out source self destination out-zone
  no service-policy type inspect ccp-permit-icmpreply
or modify your policy-map ccp-permit and ccp-permit-icmpreply:
  no class type inspect SDM_DHCP_CLIENT_PT
  class-type inspect OUT-SELF
  pass
  class class-default
  drop log
class-map type inspect OUT-SELF
match ip access-group name OUT-SELF
ip access-list extended OUT-SELF
permit icmp any any
permit tcp any any eq bootpc
permit tcp any any eq ssh
permit tcp any any eq https
service-policy type inspect SELF-OUT
policy-map type inspect SELF-OUT
class type inspect SELF-OUT
pass
class class-default
  drop log
class-map type inspect SELF-OUT
match ip access-group name SELF-OUT
ip access-list extended SELF-OUT
  permit icmp any any
permit tcp any eq ssh any
permit tcp any https any
permit tcp any eq http any
Regards.
Alain.
johnlloyd_13
Level 9
Level 9
Hi Charles,
Glad to hear your CCP and SSH now works. For the web browsing issue, kindly try re-configuring your static default routes:
ip route 0.0.0.0 0.0.0.0 dhcp 2 track 123
ip route 0.0.0.0 0.0.0.0 ISP-NEXT-HOP 2 track 456
Please remember to rate helpful posts. Thanks!
10 Replies 10
johnlloyd_13
Level 9
Level 9
Hi Charles,
You would need to add the "transport input ssh" command under your VTYs for SSH to work. See useful URL how to setup SSH on your 1841:
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Hi John,
Thanks for the reply. I checked my current config and those commands were already part of the VTYs. Im including the full config below, since it is a little complicated by slas and VPN.
BTW I am unable to ping either Fa port from the WAN side, but I can ping them both from the lan side and I have checked that both ports are up/up. Also, web browsing is extremely slow/fails/timesout. Maybe these are all related? I hope so.
Charlie
Here is the full config:
Current configuration : 12092 bytes
version 12.4
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname imd1841
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging message-counter syslog
logging buffered 51200
no aaa new-model
clock timezone EST -5
clock summer-time EST recurring
crypto pki trustpoint TP-self-signed-3459452820
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3459452820
revocation-check none
rsakeypair TP-self-signed-3459452820
crypto pki certificate chain TP-self-signed-3459452820
certificate self-signed 01
  3082024E 308201B7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33343539 34353238 3230301E 170D3131 31303235 31373334
  35375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 34353934
  35323832 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B908 A2994EE4 6E1B9B7C 8F5CAC45 510C34B2 4FD94E24 AB695477 F5AD259A
  BEEEA023 C2804D69 9FB16E84 B68BB2D8 F15591EC 1639F86A 4750CD60 E745FCDA
  9D3C5154 A0EAAD5D 8ABEF29A A059FB4E 8238299C D965C45E 922E961D FA6F0CFB
  29932B3F C5D3428C FECF43C1 64C5D3D9 1A30BC8D DDC60B7F 525A2A2D 5874B1A7
  AF8B0203 010001A3 76307430 0F060355 1D130101 FF040530 030101FF 30210603
  551D1104 1A301882 16696D64 31383431 2E696D64 65736967 6E2E6C6F 63616C30
  1F060355 1D230418 30168014 ACB35655 A6462310 4AD5A142 4FEE72EE 9F9ED125
  301D0603 551D0E04 160414AC B35655A6 4623104A D5A1424F EE72EE9F 9ED12530
  0D06092A 864886F7 0D010104 05000381 810044E2 1C68291D D66FC13D 18F57304
  9C28CBF2 31F6CEAC B070F129 ACBD82C3 2EFB9C81 159F9B3F C35703CF 469D9EBA
  49151D6B 2514804F 6705FC10 E94D04FB 2E1AC867 7706BDB0 56A07D2A 2E376B1A
  DE99D8D9 36062A65 AA29E40C FFC1F320 17F87B99 57336941 C99184CC 5952F742
  223DBB82 6DA9037B F48FB28F 92C2DE73 2EAA
        quit
dot11 syslog
ip source-route
ip cef
ip domain name mydomain.local
no ipv6 cef
ntp logging
ntp update-calendar
ntp server 129.6.15.18
ntp server 129.6.15.29
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key ******** address zz.zz.zz.zz
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec df-bit clear
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to Onshore
set peer zz.zz.zz.zz
set transform-set ESP-3DES-SHA
match address 101
archive
log config
  hidekeys
track 123 ip sla 1 reachability
track 456 ip sla 2 reachability
class-map type inspect match-all sdm-cls-VPNOutsideToInside-1
match access-group 103
class-map type inspect match-all sdm-cls-VPNOutsideToInside-2
match access-group 105
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_VPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_VPN_PT
match access-group 102
match class-map SDM_VPN_TRAFFIC
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-VPNOutsideToInside-1
class type inspect sdm-cls-VPNOutsideToInside-1
  inspect
class type inspect sdm-cls-VPNOutsideToInside-2
  inspect
class class-default
  drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
  pass
class class-default
  drop
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security sdm-zp-VPNOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-VPNOutsideToInside-1
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description $ETH-WAN$$FW_OUTSIDE$
ip address xx.xx.xx.xx 255.255.248.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface BRI0/1/0
no ip address
encapsulation hdlc
shutdown
interface Vlan1
description $FW_INSIDE$
ip address 192.168.5.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 2 track 123
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 2 track 456
ip route 4.2.2.2 255.255.255.255 FastEthernet0/1
ip route 192.55.83.30 255.255.255.255 FastEthernet0/0
ip http server
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map RMFA00 interface FastEthernet0/0 overload
ip nat inside source route-map RMFA01 interface FastEthernet0/1 overload
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
ip access-list extended SDM_AH
remark CCP_ACL Category=1
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
ip sla 1
icmp-echo 192.55.83.30
timeout 1500
threshold 10000
frequency 4
history hours-of-statistics-kept 6
history distributions-of-statistics-kept 5
history statistics-distribution-interval 10
history buckets-kept 25
history enhanced interval 900 buckets 100
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 4.2.2.2
timeout 2500
threshold 10000
frequency 4
ip sla schedule 2 life forever start-time now
logging trap debugging
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.5.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip 192.168.5.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=128
access-list 102 permit ip host 208.64.160.223 any
access-list 103 remark CCP_ACL Category=0
access-list 103 permit ip 192.168.0.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 104 remark CCP_ACL Category=2
access-list 104 deny   ip 192.168.5.0 0.0.0.255 any
access-list 104 permit ip 192.168.5.0 0.0.0.255 any
access-list 105 remark CCP_ACL Category=0
access-list 105 deny   ip 192.168.0.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 105 permit ip any 192.168.5.0 0.0.0.255
route-map RMFA00 permit 10
match ip address 101
match interface FastEthernet0/0
route-map RMFA01 permit 10
match interface FastEthernet0/1
route-map SDM_RMAP_1 permit 1
match ip address 104
control-plane
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
hi charles,
CCP:
SSH:
ip ssh time-out
int f0/0
int f0/1
int vl1
  pass
class class-default
  drop
  pass
  class class-default
  drop log
permit icmp any any
pass
class class-default
  drop log
  permit icmp any any
Regards.
Alain.
Thanks for the replies. I think this has solved the immediate problem. I made the changes offered by John and by Alain. Then I re-enabled the ZBFW on the external and internal interfaces and I am now able to access (via ssh and ccp) the router from remote.
I am still having some issues with web browsing. Often requests time-out. Here is an updated config. Does anyone see any reasons why Im having this issue?
Current configuration : 12733 bytes
version 12.4
no service pad
hostname imd1841
boot-start-marker
boot-end-marker
enable secret 5 ***********
no aaa new-model
quit
dot11 syslog
ip source-route
ip cef
no ipv6 cef
ntp logging
ntp update-calendar
username admin privilege 15 secret 5 ********
encr 3des
group 2
crypto isakmp key ********** address zz.zz.zz.zz
description Tunnel to208.64.160.223
match address 101
archive
log config
hidekeys
ip ssh time-out 30
ip ssh authentication-retries 5
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol h323
match protocol sip
match protocol http
class-map type inspect match-all SELF-OUT
match access-group name SELF-OUT
class-map type inspect match-all OUT-SELF
match access-group name OUT-SELF
pass
inspect
class class-default
pass
inspect
inspect
class class-default
drop
drop log
inspect
inspect
inspect
inspect
inspect
inspect
inspect
inspect
class class-default
drop
class type inspect OUT-SELF
pass
class class-default
drop log
pass
class class-default
drop log
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface BRI0/1/0
no ip address
encapsulation hdlc
shutdown
interface Vlan1
ip nat inside
ip http server
permit icmp any any
permit tcp any any eq www
permit ahp any any
permit esp any any
permit icmp any any
permit tcp any eq 22 any
permit tcp any eq 443 any
permit tcp any eq www any
ip sla 1
timeout 1500
threshold 10000
frequency 4
ip sla 2
icmp-echo 4.2.2.2
timeout 2500
threshold 10000
frequency 4
access-list 102 permit ip host zz.zz.zz.zz any
control-plane
line con 0
login local
line aux 0
login local
line vty 0 4
privilege level 15
login local
line vty 5 15
privilege level 15
login local
end
Are these request  timeouts random?
Can you post sh ip route and sh arp  output .
Alain.
Here is the output from those commands:
imd1841#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  4.2.2.2               154   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  23.48.92.176          122   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  24.62.176.1             0   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  24.62.177.211           0   000f.b580.0c07  ARPA   FastEthernet0/0
Internet  24.62.183.157           -   0018.1846.57f2  ARPA   FastEthernet0/0
Internet  38.114.159.1          121   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  38.114.159.3          121   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  38.114.159.45         121   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  38.114.159.62         122   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  38.114.159.63         121   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  64.4.18.90              2   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  64.94.107.23          121   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  64.94.107.38          121   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  66.30.32.45             -   0018.1846.57f3  ARPA   FastEthernet0/1
Internet  66.151.183.41         124   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  66.235.138.59         120   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  68.87.71.230          153   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  69.63.181.63          100   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  69.64.158.164         124   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  70.37.128.171          98   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  70.37.129.172          97   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  72.163.5.80           100   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.113.99           0   Incomplete      ARPA
Internet  74.125.113.103          0   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.113.105          0   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.113.106          1   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.115.120        141   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.96         105   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.97          83   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.98         153   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.102         83   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.103        141   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.105         83   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.106         82   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.108         83   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.109        123   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.161         85   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.163        153   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.172        153   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.195          0   Incomplete      ARPA
Internet  74.125.226.198          0   Incomplete      ARPA
Internet  74.125.226.202          0   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.228        153   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.229        153   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  74.125.226.231        139   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.236        153   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  74.125.226.237         84   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  75.98.38.78           123   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  129.6.15.28           153   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  138.108.6.20          120   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  173.37.144.208         88   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  184.25.109.122         99   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  184.25.109.137        121   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  192.55.83.30          154   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  192.168.5.1             -   0018.1846.57f2  ARPA   Vlan1
Internet  192.168.5.219           0   0021.70ab.d01d  ARPA   Vlan1
Internet  198.133.219.10         98   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  206.72.115.12          99   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  207.223.0.140         113   001d.4570.46e2  ARPA   FastEthernet0/1
Internet  208.64.160.223        153   001d.4570.46e2  ARPA   FastEthernet0/0
Internet  209.85.227.120         83   001d.4570.46e2  ARPA   FastEthernet0/0
imd1841#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
     68.0.0.0/32 is subnetted, 1 subnets
S       68.87.71.8 [254/0] via 24.62.176.1, FastEthernet0/0
     4.0.0.0/32 is subnetted, 1 subnets
S       4.2.2.2 is directly connected, FastEthernet0/1
     66.0.0.0/21 is subnetted, 1 subnets
C       66.30.32.0 is directly connected, FastEthernet0/1
     24.0.0.0/21 is subnetted, 1 subnets
C       24.62.176.0 is directly connected, FastEthernet0/0
C    192.168.5.0/24 is directly connected, Vlan1
     192.55.83.0/32 is subnetted, 1 subnets
S       192.55.83.30 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 is directly connected, FastEthernet0/0
Any Ideas?
Hi Alain,
I have another issue with this 1841 config.
I am unable to bring up the Zone Based Firewall since applying some of the changes you suggested in your original post. When I turn debugs on I am able to see that firewall is dropping some packets during the ISAKMP phase of bringing up the tunnel:
Here is what I am seeing in the debugs:
.Nov  2 16:15:34.283 EST: ISAKMP:(0): beginning Main Mode exchange
.Nov  2 16:15:34.283 EST: ISAKMP:(0): sending packet to xx.xx.xx.xx my_port 500 peer_port 500 (I) MM_NO_STATE
.Nov  2 16:15:34.283 EST: ISAKMP:(0):Sending an IKE IPv4 Packet.
.Nov  2 16:15:34.283 EST: %FW-6-DROP_PKT: Dropping Other session yy.yy.yy.yy:500 xx.xx.xx.xx:500 on zone-pair ccp-zp-self-out class class-default due to  DROP action found in policy-map with ip ident 0
.Nov  2 16:15:44.282 EST: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
.Nov  2 16:15:44.282 EST: ISAKMP (0): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
.Nov  2 16:15:44.282 EST: ISAKMP:(0): sending packet to xx.xx.xx.xx my_port 500 peer_port 500 (I) MM_NO_STATE
.Nov  2 16:15:44.282 EST: ISAKMP:(0):Sending an IKE IPv4 Packet.
.Nov  2 16:15:54.282 EST: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
.Nov  2 16:15:54.282 EST: ISAKMP (0): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
.Nov  2 16:15:54.282 EST: ISAKMP:(0): sending packet to xx.xx.xx.xx my_port 500 peer_port 500 (I) MM_NO_STATE
.Nov  2 16:15:54.282 EST: ISAKMP:(0):Sending an IKE IPv4 Packet.
.Nov  2 16:16:03.105 EST: %FW-6-LOG_SUMMARY: 5 packets were dropped from yy.yy.yy.yy:500 => xx.xx.xx.xx:500 (target:class)-(ccp-zp-self-out:class-default)
Here are the relevant zone/policy/class statements:
class type inspect SDM_VPN_PT
  pass
  pass
class class-default
  drop log
  pass
class class-default
  drop log
match access-group 104
access-list 104 remark CCP_ACL Category=128
access-list 104 permit ip host xx.xx.xx.xx any
permit icmp any any
permit icmp any any
The Debug error seems to point to the self-out class-default DROP action? What would I need to add in order to allow the VPN tunnel to come up?
TIA
johnlloyd_13
Level 9
Level 9
Hi Charles,
Not sure what you are referrring to in each of these statements:
1. 'dhcp' This is currently FastEthernet0/0 in the current config. To what would dhcp refer?
2. 'ISP-NEXT-HOP' This is currently FastEthernet0/1 in the current config. Likewise to what should this refer?
TIA
I think I figured this out. For both of these items I placed the default gateway address assigned by the isp. Now things are moving a lot faster.
Thanks!
