Policy based routing problem - multiple subnets starange behavior
dlandriscina
Hey.. Got a really weird situation which is driving me crazy.  Please help
2 Subnets - Vlan1- 192.168.100.0/24 , Vlan2 - 192.168.0.0/24
2 ISPS - Verizon,Optimum
Email server host 192.168.100.7 set through route-map policy to go out through Verizon.  Always has worked. Still works
When I internally ping to/from subnet 192.168.0.0 - I cant hit this machine or vice/versa.  Anything from subnet 192.168.100.0 pings/communicates/routes properly
Attached is the config pieces for the routemap.
interface FastEthernet0
 description Verizon T1
 bandwidth 1544
 ip address ISP1_IP
 ip access-group 101 in
 ip nat outside
 ip inspect DEFAULT100 out
 ip virtual-reassembly
 ip route-cache flow
 duplex auto
 speed auto
interface FastEthernet1
 description Optimum
 ip address ISP2_IP
 ip nat outside
 ip route-cache flow
 duplex auto
 speed auto
 crypto map SITETOSITE
interface Vlan1
 description Internal
 ip address 192.168.100.1 255.255.255.0
 ip access-group 100 in
 ip nat inside
 ip route-cache flow
 ip policy route-map EMAILSERVER
interface Vlan2
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 ip route-cache flow
ip route 0.0.0.0 0.0.0.0 ISP2_DEFAULT_GATEWAY
ip route 0.0.0.0 0.0.0.0 ISP1_DEFAULT_GATEWAY 254
ip nat inside source route-map OPTIMUM interface FastEthernet1 overload
ip nat inside source static tcp 192.168.100.7 23 interface FastEthernet0 23
ip nat inside source static tcp 192.168.100.7 110 interface FastEthernet0 110
ip nat inside source static tcp 192.168.100.7 80 interface FastEthernet0 80
ip nat inside source static tcp 192.168.100.7 443 interface FastEthernet0 443
ip nat inside source static tcp 192.168.100.7 1352 interface FastEthernet0 1352
ip nat inside source route-map EMAILSERVER interface FastEthernet0 overload
ip nat inside source route-map VERIZON interface FastEthernet0 overload
ip nat inside source static tcp 192.168.100.7 25 interface FastEthernet0 25
ip nat inside source static tcp 192.168.100.9 47 interface FastEthernet1 47
ip nat inside source static udp 192.168.100.9 47 interface FastEthernet1 47
ip nat inside source static tcp 192.168.100.9 1723 interface FastEthernet1 1723
ip access-list extended VERIZON-ACL
 permit ip host 192.168.100.7 any
logging trap debugging
logging 192.168.0.31
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 permit 192.168.100.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 192.168.110.0 0.0.0.255
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 permit udp any any eq non500-isakmp
access-list 101 permit udp any any eq isakmp
access-list 101 permit esp any any
access-list 101 permit ahp any any
access-list 101 permit gre any any
access-list 101 permit udp any any eq ntp
access-list 101 permit tcp any any eq 1723
access-list 101 permit udp any any eq 1723
access-list 101 permit tcp any any eq 1352
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq smtp
access-list 101 permit tcp any any eq pop3
access-list 101 deny   ip 192.168.100.0 0.0.0.255 any
access-list 101 deny   ip 192.168.0.0 0.0.0.255 any
access-list 101 deny   ip 10.0.0.0 0.0.0.255 any
access-list 101 permit udp any any eq domain
access-list 101 permit udp any eq domain any
access-list 101 permit tcp any any eq domain
access-list 101 permit tcp any eq domain any
access-list 101 permit udp host 64.115.0.9 eq domain any
access-list 101 permit udp host 64.115.0.10 eq domain any
access-list 101 permit udp host 67.206.254.2 eq domain any
access-list 101 permit udp host 207.172.3.8 eq domain any
access-list 101 permit udp host 167.206.112.138 eq domain any
access-list 101 permit udp host 167.206.7.4 eq domain any
access-list 101 permit udp host 208.67.222.222 eq domain any
access-list 101 permit udp host 208.67.220.220 eq domain any
access-list 101 permit udp host 8.8.8.8 eq domain any
access-list 101 permit udp host 8.8.4.4 eq domain any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip host 0.0.0.0 any
access-list 101 deny   ip any any
access-list 102 deny   ip 192.168.100.0 0.0.0.255 192.168.110.0 0.0.0.255
access-list 102 remark VERIZON ROUTEMAP ACL
access-list 102 permit ip 192.168.100.0 0.0.0.255 any
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
access-list 102 permit ip 10.0.0.0 0.0.0.255 any
access-list 103 deny   ip 192.168.100.0 0.0.0.255 192.168.110.0 0.0.0.255
access-list 103 deny   ip host 192.168.100.7 any
access-list 103 permit ip 192.168.100.0 0.0.0.255 any
access-list 103 permit ip 192.168.0.0 0.0.0.255 any
access-list 103 permit ip 10.0.0.0 0.0.0.255 any
route-map EMAILSERVER permit 9
 match ip address VERIZON-ACL
 match interface FastEthernet0
 set ip next-hop ISP1_DEFAULT_GATEWAY
route-map VERIZON permit 1
 match ip address 102
route-map OPTIMUM permit 1
 match ip address 103
 match interface FastEthernet1
7 Replies 7
Can you share the logs of show access-list 103 and show access-list 102?
Absolutely
#show access-list 102
Extended IP access list 102
    10 deny ip 192.168.100.0 0.0.0.255 192.168.110.0 0.0.0.255
    20 permit ip 192.168.100.0 0.0.0.255 any (1 match)
    30 permit ip 192.168.0.0 0.0.0.255 any
    40 permit ip 10.0.0.0 0.0.0.255 any
R1#show access-list 103
Extended IP access list 103
    20 deny ip host 192.168.100.7 any (2775 matches)
    30 permit ip 192.168.100.0 0.0.0.255 any (44855 matches)
    40 permit ip 192.168.0.0 0.0.0.255 any (3561 matches)
    50 permit ip 10.0.0.0 0.0.0.255 any
Any update on this ? Thanks
Sorry for late response...I was stuck somewhere else.
Can you make the following change and I believe,you will be able to access from 192.168.0.0/24 network to 192.168.100.7.
IP access-list  extended VERIZON-ACL
 no 10 permit ip host 192.168.100.7 any
10 deny ip host 192.168.100.7 192.168.0.0 0.0.0.255
 20 permit ip host 192.168.100.7 any.
did you make the change? Please let me know the result. I simulated the same scenario and the acl change solved the issue.
Hello Rahul,
I just applied this and it did indeed fix the problem.  Thank you very much.
Can you please explain why this was needed to make this work?
Thanks!
As per Route-map "EMAILSERVER" traffic from 192.168.100.7 to any destination will be forwarded to "ISP1_DEFAULT_GATEWAY" and "ISP1_DEFAULT_GATEWAY" will send an icmp destination unreachable message to 192.168.100.7. With change in acl configuration for this route-map now traffic to 192.168.0.0/24 network will not be forwarded to "ISP1_DEFAULT_GATEWAY" however it will be forwarded per local routing table.
Can you please rate me if I solved your problem.
