Policy based routing problems or perhaps bug?
mis_dept1
Ok, I have successfully configured PBR on my ASA 5515x with the help from the community here. :D
As shown below is my configuration in GUI Based as well as CLI Based (Both are the same)
Problem:
1. What does the warning mean (scroll down)? It says that the ACL has no effect?
2. When I am downloading large files for testing, (from http://www.thinkbroadband.com/download.html or any other test sites) my download will be stuck halfway, and it does not resumes. (Download speed is about 7MB/s)
When I connect my laptop directly to the ISP2 router, I am able to download successfully.
This eliminates the following:
- My ISP is having issues.
- thinkbroadband.com is having issues.
I am using CX module for my IPS. I suspect that the IPS is unable to keep up with the speed of the download, and it drops the packets?
3. After applying the extended ACL to the route map, I am not able to access my web server in my DMZ zone anymore, (RDP, ping, http/https). In fact, all of my DMZ servers are not accessible unless I remove myself from the ACL.
This is happening because my next hop is set to ISP2ROUTER. In my case, is there any way to add another rule like: Do not use next hop from INSIDE to DMZ.
GUI based- configuration
Step 1: Created Extended ACL
Step 2: Created Route Map
When I attempted to click on the next tab, a warning appears, and I clicked OK.
Not sure what does this mean.
Step 3: Add the next hop. (ISP 2 Router IP.) and set it to ISP2 Outside interface
When I click on Apply:
Step 4: Apply route map to INSIDE interface:
CLI BASED configuration
ciscoasa(config)# access-list TESTACL permit ip 172.16.1.53 255.255.255.255 any
ciscoasa(config)# route-map TESTROUTEMAP permit 1
ciscoasa(config-route-map)# match ip address TESTACL
WARNING: If access-list TESTACL having destination "any\any4\any6" is used as match criteria for a route map, and applied to any routing protocol it will not have any effect. Instead use standard ACL or extended ACL without any\any4\any6 in destination.
ciscoasa(config-route-map)# set ip next-hop 1.1.1.1
ciscoasa(config-route-map)# set interface ISP2UNTRUST
ciscoasa(config-route-map)# exit
ciscoasa(config)# interface GigabitEthernet0/2
ciscoasa(config-if)# policy-route route-map TESTROUTEMAP
mis_dept1
Bump up.
