Policy based routing
john.barber
I am trying to set up policy based routing on a Cisco 2960XR. IoS version 152.2.E5. This will be used to route depending on source IP address.
I have added an ACL and created the route-map however when I try to apply it to the interface, the option in the example is not available. The example state
switch(config)#interface gigabitethernet 1/0/1
switch(config-if)#ip policy route-map pbr-map
When I try to add my route-map to an interface, there is no option for 'policy' after entering ip ?
all I am offered is
access-group
admission
arp
device
dhcp
flow
igmp
verify
Is this down to IoS version or am I missing something, e.g a service or something I need to enable.
John
Just apply the PBR to the SVI, that is what you should be doing anyway and this will achieve what you want.
I suspect you cannot use the interface as it was not configured as a L3 interface but regardless from your description the SVI is where you should be applying the route map.
Jon
10 Replies 10
Jon Marshall
Hi Jon
>From what I have read, the 2960XR only comes with the IP Lite feature set so assumed it would be enabled.
I think you need 15.2(6)E2. Check the release notes and scroll down to High Performance Routing (IP Lite Image):
--> Policy-based routing (PBR) allows superior traffic control by providing flow redirection regardless of the routing protocol configured.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15_2_6_e/release_notes/rn-1526e2-2960x-xr.html#High%20Performance%20Routing%20(IP%20Lite%20Image)
John
Apologies, I have not used those switches and just assumed there were multiple feature sets available (teach me to be more careful next time).
I think Georg is right ie. you may need to upgrade the IOS.
Jon
Mike.Cifelli
What is the rest of your config under interface gigabitethernet 1/0/1?  If this interface is a L2 switchport you will not have the ip policy command set.  If the interface is a trunk, and you are attempting to steer traffic for a specific VLAN then apply the route-map under that SVI.  Hope this helps.
majid.jaffari1
The best way to find the solution is, please post the configuration here after removing the sensitive information.
Best regards,
Hi All and thanks for your responses.
1. I have updated to 15.2(6)E2 and I still get the same options, no IP Policy.
2. Although I don't get the option for IP Policy on the interface, I do get it on the SVI.
3. I think I have found a solution using the IP Access-group command but im not sure that is doing what I think its doing.
Here is a cut down copy of the config. What I am trying to achieve is;
traffic coming into the switch on interfaces G1/0/47 and 48 from our firewall is checked for source address. If it matches the address in access-list 102 it is send down interface G1/0/25. If it doesn't match it sends it out interface G1/0/49
version 15.2
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
boot-start-marker
boot-end-marker
aaa session-id common
switch 1 provision ws-c2960xr-48fpd-i
system mtu routing 1500
ip routing
no setup express
spanning-tree mode pvst
vlan 20
 name FW_N3_Uplink
vlan 30
 name HSCN_Uplink
interface FastEthernet0
 no ip address
 no ip route-cache
interface GigabitEthernet1/0/1
 shutdown
interface GigabitEthernet1/0/25
 description "Link to HSCN"
 switchport access vlan 30
 switchport mode access
interface GigabitEthernet1/0/47
 description "Link to FW01 Cab 10"
 switchport access vlan 20
 ip access-group 102 in
interface GigabitEthernet1/0/48
 description "Link to FW01 Cab 11"
interface GigabitEthernet1/0/49
 description "Link to BT"
 switchport mode trunk
 srr-queue bandwidth share 10 10 60 20
 queue-set 2
 priority-queue out
 mls qos trust dscp
 auto qos voip trust
interface Vlan20
 ip address 10.1.1.2 255.255.255.240
interface Vlan30
 ip address 10.2.2.2 255.255.255.252
ip forward-protocol nd
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.1.1.1
ip ssh version 2
access-list 102 permit ip 10.3.3.0 0.0.0.127 any
route-map HSCN-Traffic permit 10
 match ip address 102
 set ip next-hop 10.2.2.1
Thanks.
John
Jon
Many thanks Jon.
Hello
what sdm template are you running?
sh sdm prefer
Kind Regards
Paul
