policy-map with set ip dscp not working
Hello everyone,
I currently have the following configuration setup on a Cisco 2901 router. However, the configuration isn't work as expected. The expected outcome is for the dscp values to be assigned as they leave the WAN interface. However, the values aren't being set (verified with tcp dump). Any help would be greatly
appreciated.
class-map match-all VIDEO-TCP
match access-group name VIDEO-TCP
class-map match-all VIDEO-UDP
match access-group name VIDEO-UDP
policy-map WAN_PM
class VIDEO-TCP
  set ip dscp cs3
class VIDEO-UDP
  set ip dscp af41
interface GigabitEthernet0/0
service-policy output WAN_PM
ip access-list extended VIDEO-TCP
permit tcp xxx.xxx.xxx.16 0.0.0.7 any
permit tcp any xxx.xxx.xxx.16 0.0.0.7
ip access-list extended VIDEO-UDP
permit udp xxx.xxx.xxx.16 0.0.0.7 any
permit udp any xxx.xxx.xxx.16 0.0.0.7
9 Replies 9
Hello
Try to apply your dscp marking ingress on the LAN interface of your router and amend your acl's
permit tcp x.x.x.x y.y.y.y 16.0.0.0
permit UDP x.x.x.x y.y.y.y 16.0.0.0
Int xx(LAN interface)
Service-policy input policy-map
Res
Paul
Kind Regards
Paul
I'm not tracking. I need it to apply as it leaves the outbound interface.
Can you post "show policy-map interface"?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
show policy-map yields no results (e.g. no counter increases)
    Class-map: VIDEO-TCP (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: access-group name VIDEO-TCP
      QoS Set
        dscp cs3
          Packets marked 0
    Class-map: VIDEO-UDP (match-all)
      0 packets, 0 bytes
      Match: access-group name VIDEO-UDP
      QoS Set
        dscp af41
          Packets marked 0
    Class-map: class-default (match-any)
      9484 packets, 1961637 bytes
      5 minute of
Hello
Dont understand what you mean by tracking - if you mark the traffic as in enters your wan router from you lan then as it egresses out of the wan interface it will have it defined traffic marked with the the dscp.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Same result even if on the LAN
Aaron
It sounds like you may not be matching on the correct IPs which we can't verify because you haven't posted them.
Also is NAT involved anywhere ?
Perhaps if you could you provide a few more details.
In addition what is the IOS version ?
Jon
This definitely should work. I agree with Jon about not matching the correct addresses. Is there a way that you could post your complete interface config? This works fine on 12.4 in GNS, and I have sites running 15.2 that it works well on as well.
HTH,
John
Hello
Looks possibly like you acl's are incorrect
I have just tested this and it works for me.
ip access-list extended UDP
permit udp any host 3.3.3.3 eq tftp
ip access-list extended icmp
permit icmp host 111.111.111.111 host 133.133.133.33 echo
permit icmp host 133.133.133.33 host 111.111.111.111 echo-reply
ip access-list extended tcp
permit tcp host 1.1.1.1 host 3.3.3.3 eq telnet
class-map match-all ICMP
match access-group name icmp
match input-interface FastEthernet0/0
class-map match-all UDP
match access-group name UDP
class-map match-all TCP
match access-group name tcp
policy-map TST
class ICMP
  set dscp af12
class TCP
  set dscp af23
class UDP
  set dscp cs4
Description LAN Interface
service-policy input TST
sh policy-map interface  fa0/0
FastEthernet0/0
  Service-policy input: TST
    Class-map: ICMP (match-all)
      100 packets, 11400 bytes
      5 minute offered rate 3000 bps, drop rate 0 bps
      Match: access-group name icmp
      Match: input-interface FastEthernet0/0
      QoS Set
        dscp af12
          Packets marked 100
    Class-map: TCP (match-all)
      10 packets, 606 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name tcp
      QoS Set
        dscp af23
          Packets marked 10
    Class-map: UDP (match-all)
      4 packets, 240 bytes
      Match: access-group name UDP
      QoS Set
        dscp cs4
          Packets marked 4
      13 packets, 795 bytes
      Match: any
res
Paul
Thanks.
Kind Regards
Paul
