08-21-2005 11:55 PM - edited 03-03-2019 10:19 AM
Does anyone know if there is an equivelant or workaround of Policy NAT (from PIX) on IOS routers?
Gareth
Solved! Go to Solution.
08-22-2005 06:30 AM
You can use NAT with route-maps to translate hosts to different public addresses.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
Check the section "Route-map approach"
08-22-2005 06:30 AM
08-22-2005 07:27 AM
This is exactly what I need... many thanks,
Gareth
