policy routing-Cef/Fib
ccobtn
I have question about policy-routing with regard to next-hop ip. Does next-hop ip have to existed in the Cef/fib table for policy to work?.
Reason being is that if I make next-hop ip via address learn from routing table I get policy reject and routed normal way. But If I make next-hop ip explicit via directly connected address which exist in the cef/fib table then policy works fine.
here is config......
access-list 110 permit tcp any any eq www
route-map http permit 10
match ip address 110
set ip next-hop verify-availability 192.168.5.2 5 track 123
C 172.10.10.0 is directly connected, GigabitEthernet1/0/9
172.16.0.0/24 is subnetted, 1 subnets
C 172.16.20.0 is directly connected, GigabitEthernet1/0/1
R 192.168.5.0/24 [120/1] via 172.16.20.2, 00:00:05, GigabitEthernet1/0/1
10.0.0.0/24 is subnetted, 2 subnets
C 10.10.2.0 is directly connected, GigabitEthernet1/0/13
O IA 10.10.3.0 [110/2] via 10.10.2.2, 00:25:47, GigabitEthernet1/0/13
ws-sw#sh ip cef
Prefix Next Hop Interface
0.0.0.0/32 receive
10.10.2.0/24 attached GigabitEthernet1/0/13
10.10.2.0/32 receive
10.10.2.1/32 receive
10.10.2.2/32 attached GigabitEthernet1/0/13
10.10.2.255/32 receive
10.10.3.0/24 10.10.2.2 GigabitEthernet1/0/13
172.10.10.0/24 attached GigabitEthernet1/0/9
172.10.10.0/32 receive
172.10.10.1/32 receive
172.10.10.100/32 attached GigabitEthernet1/0/9
172.10.10.255/32 receive
172.16.20.0/24 attached GigabitEthernet1/0/1
172.16.20.0/32 receive
172.16.20.1/32 receive
172.16.20.2/32 attached GigabitEthernet1/0/1
172.16.20.255/32 receive
192.168.5.0/24 172.16.20.2 GigabitEthernet1/0/1
224.0.0.0/4 drop
224.0.0.0/24 receive
255.255.255.255/32 receive
ws-sw#
00:28:35: CEF-IP-POLICY: fib for address 192.168.5.2 is with flag 0
00:28:35: IP: s=172.10.10.100 (GigabitEthernet1/0/9), d=192.168.5.2, len 40, FIB
policy rejected - normal forwarding
policy match
00:28:39: IP: s=172.10.10.100 (GigabitEthernet1/0/9), d=192.168.5.2, len 40, FIB
policy match
00:28:39: CEF-IP-POLICY: fib for address 192.168.5.2 is with flag 0
policy match
set ip next-hop verify-availability 172.16.20.2 5 track 123
0:41:01: IP: s=172.10.10.100 (GigabitEthernet1/0/9), d=192.168.5.2, len 48, FIB
policy match
00:41:01: IP: s=172.10.10.100 (GigabitEthernet1/0/9), d=192.168.5.2, g=172.16.20
.2, len 48, FIB policy routed
00:41:01: IP: s=172.10.10.100 (GigabitEthernet1/0/9), d=192.168.5.2, len 40, FIB
policy match
.2, len 40, FIB policy routed
00:41:01: IP: s=172.10.10.100 (GigabitEthernet1/0/9), d=192.168.5.2, len 284, FI
B policy match
.2, len 284, FIB policy routed
00:41:01: IP: s=172.10.10.100 (GigabitEthernet1/0/9), d=192.168.5.2, len 331, FI
B policy match
Harold Ritter
Use of the recursive next-hop (non-directly connected) with PBR route-map is supported starting with 12.3(14)T or 12.0(28)S. For more information, please refer to the following URL:
http://www/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a008021de72.html
Hope this helps,
Is this mean that policy routing "next-hop" is only supported with ip address (which is directly adjacent) and indirect next-hops will not work.
At moment i'm using Cat 3750 and is there cat software that suport recursive next-hop (non-directly connected ?)
Regard
You are correct. Without the PBR recursive next-hop feature, you can only specify a directly connected NH.
Unfortunately, the latest 12.2SE code (12.2(25)SEB2) for the 3750 doesn't support this feature.
Hope this helps,
