Policy routing on cat3750E
device: WS-C3750E-24TD 12.2(44)SE2 C3750E-UNIVERSAL-M
have any SVI interfaces ...
i want FORWARD certain traffic to DEST_NET if NOT FOUND in local route table, other traffic forward bt default ... this task NOT complex if command: ip-policy route-map <...> use on any SVI interfaces...but this not normal solution
i'm prob:
ip route DEST_NET lo0
int lo0
ip policy route-map <..>
route-map <..>
match from ACL (sources for policy)
set ip next-hop (router for DEST_NET)
but traffic not received on interface Lo0
pbr no work
main task:
1. If traffic from <SOURCE_IP> local route table (RT) NOT route to <DEST_NET> - FORWARD traffic to specified next-hop
2. If traffic from <SOURCE_IP> to <LOCAL_NET> (network lean local router) found in RT traffic must forward default
3. All other traffic forward by default
solution ONLY for many SVI (10-30)
example BAD solution:
route-map ONE permit 10
desc __ALLOW_local_traffic__
match acl <SOURCE_IP_LOCAL_NET>
route-map ONE permit 15
desc __FORWARD SOURCE_IP traffic to R2
match ACL <SOURCE_IP>
set ip next-hop <R2>
route-map ONE permit 20
desc DEFAULT forward other traffic
acl: SOURCE_IP - list of clients for policy
acl: SOURCE_IP_LOCAL_NET - trafic from SOURCE_IP -> LOCAL_net
conf t int vlan20x
ip policy route-map ONE
exit
many many SVI
conf t int vlan299
Giuseppe Larosa
Hello Alexandr,
if you want PBR to use routing table first you need to use the set action
set ip default next-hop
in your route-maps clauses
Hope to help
Giuseppe
set ip default next-hop not support:
Policy-based routing based on packet length, TOS, set interface, set default next hop, or set default
interface are not supported. Policy maps with no valid set actions or with set action set to Don't
Fragment are not supported.
Hello Alexandr,
I was afraid of this I haven't checked the config guide before posting.
I don't see any other way to do this: may be you could use floating static (with high AD)routes pointing to the intended next-hop.
Hope to help
Giuseppe
No,
only SOURCE routing...
traffic from certain must be forward R2, if destination in exist RT forward default.
now testing:
ip route Lo0
now result - now traffic in lo0
then add:
ip route null0
i see traffic on lo0 in pbr:
[syslog@9 s_sn="4101374" s_tc="4132879"]: 4127611: May 12 17:13:48.746: IP: route map TEST, item 10, permit
[syslog@9 s_sn="4101375" s_tc="4132880"]: 4127612: May 12 17:13:48.746: IP: Loopback0 to Vlan51 x.x.x.x
but traffic forward with problem (every seconds packets loss)...
