Port forwarding on cisco 1841 don't work
cyberburn07
I'm trying to setup port forwarding to a citrix server but,
it seems not to be working, can someone please tel me what I'm doing wrong
As you can see I'm using dyndns an I have verified its working by pinging the host ...
Building configuration...
Current configuration : 1998 bytes
version 12.4
hostname **********
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip name-server 208.67.220.220
ip name-server 208.67.222.222
ip ddns update method DYNDNS
HTTP
  add http:/**************@members.dyndns.org/nic/updatesystem=dyndns&hostname=<h>&myip=<a>
interval maximum 0 2 0 0
no ipv6 cef
username *********** privilege 15 password 0 ***************
archive
log config
  hidekeys
interface FastEthernet0/0
description INTERNAL_INTERFACE
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
description ADSL_INTERFACE
no ip address
ip mask-reply
ip directed-broadcast
ip flow ingress
no atm ilmi-keepalive
pvc 8/35
  pppoe-client dial-pool-number 1
interface ATM0/1/0
no ip address
shutdown
interface Dialer0
ip ddns update hostname *****************.dyndns.biz
ip ddns update DYNDNS
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname *************************
ppp chap password 0 ****************
ppp pap sent-username **************** password 0 *******************
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list INTERNET interface Dialer0 overload
ip nat inside source static tcp 192.168.0.247 443 interface Dialer0 443
ip access-list extended INTERNET
permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
   Your configuration looks good to me. Please post the output of "show ip nat transalation | include 192.168.0.247" when you're connecting from the internet to this server. I just wanna make sure how NAT works for this entry.  Can you connect this server within Lan segment while testing?
    Just note for you : You should get a problem when trying to manage this router from the internet. I'd change the ACL below:
no permit ip any any
permit ip 192.168.0.0 0.0.0.255 any
HTH,
Toshi
We do have a netgear router configured and that works...I can connect from the internal lan though.
I will post the results tomorrow.
Thanks for the reply
  I think you might need the following command to get Citrix work.
Please try this:
interface Dialer0
ip tcp adjust-mss 1380
HTH,
Toshi
Thanks I'll give that a go...
