Port-forwarding over GRE tunnel
Black_Rabbit
Hello!
I have two branch routers. Between them GRE tunnel is configured.
Traffic successfully routed from one segment to another.
I need to set up port forwarding (static NAT) so that the packets to the external interface of the branch 1 router are forwarded to the branch 2 server through the tunnel.
Port forwarding on a branch 1 nodes running successfully, but on the branch nodes 2 - does not work. =(
My configuration:
####### Router 1 #######
interface Tunnel512001
ip address 172.20.100.2 255.255.255.252
ip hello-interval eigrp 20 20
ip hold-time eigrp 20 60
ip nat inside
ip virtual-reassembly
tunnel source 1.1.1.1
tunnel destination 2.2.2.2
interface FastEthernet0/0
ip address 10.51.231.130 255.255.255.128
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description UPLINK
ip address 1.1.1.1 255.255.255.248
ip nat outside
duplex auto
speed auto
no cdp enable
ip route 0.0.0.0 0.0.0.0 1.1.1.254
ip nat inside source list 101 interface FastEthernet0/1 overload
ip nat inside source static tcp 10.51.231.72 25 195.128.57.138 25 extendable
access-list 101 deny   ip 10.51.231.0 0.0.0.255 10.51.0.0 0.0.255.255
access-list 101 deny   ip 10.51.231.0 0.0.0.255 172.20.0.0 0.0.255.255
access-list 101 permit ip 10.51.231.0 0.0.0.255 any
####### Router 2 #######
ip address 172.20.100.1 255.255.255.252
ip virtual-reassembly in
tunnel source 2.2.2.2
tunnel destination 1.1.1.1
interface GigabitEthernet0/0
ip address 10.51.231.65 255.255.255.192
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1/0
description UPLINK
no ip address
speed 1000
media-type sfp
no cdp enable
interface GigabitEthernet0/1/0.399
encapsulation dot1Q 399
ip address 2.2.2.2 255.255.255.252
ip nat outside
ip nat inside source list 101 interface GigabitEthernet0/1/0.399 overload
ip route 0.0.0.0 0.0.0.0 2.2.2.254
access-list 101 deny   ip 10.51.231.64 0.0.0.63 10.51.0.0 0.0.255.255
access-list 101 deny   ip 10.51.231.64 0.0.0.63 172.20.0.0 0.0.255.255
access-list 101 permit ip 10.51.231.64 0.0.0.63 any
I read a few articles, but was not able to understand what goes wrong. With IP reachability all is OK.
Each subnet is present int the routing table of the opposite router. Ping and telnet within the network go without problems.
But telnet 1.1.1.1 on port 25 is interrupted due to a timeout.
Tell me, please, how can I fix it?
Black_Rabbit
Hi all!
I solved the problem.
Solution:
ip access-list extended PORT_FW
permit ip host 10.51.231.72 any
route-map PORT_FW permit 10
match ip address PORT_FW
set ip next-hop 172.20.100.2
ip policy route-map PORT_FW
