port mapping
gaurav bhardwaj
Level 3
Level 3
i have two router both connect by serial link R1 and R2
now what i want R2 recieve telnet on port 8000 not on port 23 from R1.Please tell me how can i do achive this
what i did
i configure ip port map
conf t
ip port-map telnet port 8000
it is not working
second q is when i debug telnet on r2
then i recieve this message
*Mar  1 01:29:44.583: Telnet98: 1 1 251 1
*Mar  1 01:29:44.587: TCP98: Telnet sent WILL ECHO (1)
*Mar  1 01:29:44.587: Telnet98: 2 2 251 3
*Mar  1 01:29:44.587: TCP98: Telnet sent WILL SUPPRESS-GA (3)
*Mar  1 01:29:44.587: Telnet98: 80000 80000 253 24
*Mar  1 01:29:44.587: TCP98: Telnet sent DO TTY-TYPE (24)
*Mar  1 01:29:44.587: Telnet98: 10000000 10000000 253 31
*Mar  1 01:29:44.587: TCP98: Telnet sent DO WINDOW-SIZE (31)
*Mar  1 01:29:44.603: TCP98: Telnet received WILL WINDOW-SIZE (31)
*Mar  1 01:29:44.603: TCP98: Telnet received WILL TTY-SPEED (32) (refused)
*Mar  1 01:29:44.607: TCP98: Telnet sent DONT TTY-SPEED (32)
*Mar  1 01:29:44.611: TCP98: Telnet received WILL TTY-TYPE (24)
*Mar  1 01:29:44.611: Telnet98: Sent SB 24 1
*Mar  1 01:29:44.615: TCP98: Telnet received WILL NEW-ENVIRON (39)
*Mar  1 01:29:44.619: TCP98: Telnet sent DONT NEW-ENVIRON (39) (unimplemented)
*Mar  1 01:29:44.623: TCP98: Telnet received DO ECHO (1)
*Mar  1 01:29:44.623: TCP98: Telnet received WILL SUPPRESS-GA (3)
*Mar  1 01:29:44.627: TCP98: Telnet sent DO SUPPRESS-GA (3)
*Mar  1 01:29:44.627: TCP98: Telnet received DO SUPPRESS-GA (3)
*Mar  1 01:29:44.627: Telnet98: recv SB NAWS 110 24
*Mar  1 01:29:44.647: Telnet98: recv SB 24 0 XTERM
*Mar  1 01:29:44.655: TCP98: Telnet received WILL ENVIRONMENT (36) (refused)
*Mar  1 01:29:44.659: TCP98: Telnet sent DONT ENVIRONMENT (36)
my q is how do i found that on which port telnet recieve query
thankyou
cadet alain
apart from port 23, you can use port 3000( and additionally ports 5000,7000 and 10000) + rotary group number like this:
line vty 0 4
rotary 20
---> will listen on 3020,5020,7020 and 10020
rotary-group goes from 1 to 127.
you'll have to use an access-list to block port 23 because it will still listen to it.
to see the tcp port in listening state: show tcp brief all
Regards.
Alain
